         Plano_Mike Newbie
           | Posted: September 17 2006 at 23:29 | IP Logged
Dave--
 I got a new Powerlinc serial with firmware vers. 2.13.  I am getting the following error message in the SDM:
 PLC:ERROR=012:MapNotLoaded-PLC not connected or no valid map. Try using isResponding first.
 PLC:sendinsteonraw=True
 Do I need a newer version of the SDM (I am running 1.01.79.226)?
 TIA
 Mike
  __________________ Mike
           | Posted: September 20 2006 at 22:50 | IP Logged
Mike,
 I would definately upgrade to the latest SDM on the PowerHome site (version 235).  If you have access, the latest version 278 works as well.  In any event, you need the proper map for your device which Ive uploaded for you here: http://power-home.com/download/plc3-2d.zip.  Later versions of the SDM already have this (not sure if 235 does or not).
         Plano_Mike Newbie
           | Posted: September 20 2006 at 23:18 | IP Logged
Sorry for a dumb question, but...
 I'm having difficulty locating the new SDM on the PH site.  Please instruct where to find it.
 Thanks.
 Mike
           | Posted: September 21 2006 at 07:30 | IP Logged
This is the latest I can find...
 http://www.power-home.com/download/sdm227.zip.
         Plano_Mike Newbie
           | Posted: September 21 2006 at 09:02 | IP Logged
Thanks, TonyNo.
 That is the one I have.  It reports version 226 when running.
