Subject Topic: ph_insteonrawgroup Post ReplyPost New Topic
UpstateMike
Posted: June 22 2006 at 23:18 | IP Logged Quote UpstateMike
I linked a lamp to Powerlinc1 group 1 and am trying to control it with the command below. It doesn't work and I can't figure out what I did wrong...
ph_insteonrawgroup("POWERLINC1" 1, 17, 0)
Any ideas?
Posted: June 23 2006 at 07:28 | IP Logged Quote TonyNo
I'm assuming that the forum stripped out the first comma.
Maybe these apply?
Thread 1
Thread 2
UpstateMike
Posted: June 23 2006 at 09:47 | IP Logged Quote UpstateMike
Thread 2 was it! I was confusing the controller name with the Insteon name. Thanks!
UpstateMike
Posted: June 23 2006 at 09:54 | IP Logged Quote UpstateMike
Is there any down side to using the same name for the Controller Name and the Insteon Device Name. What if I call them both PowerHome for simplicity?
Posted: June 23 2006 at 23:30 | IP Logged Quote dhoward
Mike,
Should be no problem...they are both within different primary keys so nothing database wise will keep you from doing it.
It does get confusing sometimes with all the different ID's and when/where to use what.
