Subject Topic: Replacing a device Post ReplyPost New Topic
Lazyman
Posted: June 08 2006 at 23:46 | IP Logged Quote Lazyman
I had a keypadlinc go bad and had to replace it. Since it was my first time doing this, I screwed it up.
Eventually, I somehow got it right (at least the link list showed all the lincs with the proper addresses).
Everything listed as verified. However, the links do not work. At this point the Insteon units look correct and I can control the keypadlinc from Powerhome (there is no load on the switch, but the button switches from on to off).
However, it does not control the switchlinc dimmer it is cross linked to. It also does not respond to that dimmer.
Back to Top View Lazyman's Profile Search for other posts by Lazyman
Lazyman
Posted: June 09 2006 at 00:02 | IP Logged Quote Lazyman
Never mind. Figured it out.
