Subject Topic: Help with Webserver: webserver|trustedips Post ReplyPost New Topic
onhiatus
Posted: May 29 2006 at 18:49 | IP Logged Quote onhiatus
So I'm trying to get the PH webserver up and running.
When I try to set it up in the explorer (Setup > Web) I get an error dialog: "An error occured while trying to retrieve the value for: webserver|trustedips" and the ph immediately exits?
I'm running release 1.03.4.3 (DB 1.03.6)
Thoughts?
Thanks, The other Tony
Back to Top View onhiatus's Profile Search for other posts by onhiatus Visit onhiatus's Homepage
Posted: May 29 2006 at 21:14 | IP Logged Quote TonyNo
Do you have any trusted ip's entered?
onhiatus
Posted: May 29 2006 at 23:01 | IP Logged Quote onhiatus
No. No settings at all. I can't get to the setup tab to enter any settings because of the above error...
Manny
Posted: May 30 2006 at 01:22 | IP Logged Quote Manny
When you say no settings at all does that mean your powerhome.ini file has no entries in the [WebServer] section?
Back to Top View Manny's Profile Search for other posts by Manny
Posted: May 30 2006 at 10:21 | IP Logged Quote dhoward
When you get an error message such as above, it means that parameters are missing in your pwrhome.ini file. In this case the [WebServer] section. Your INI file may not have gotten properly upgraded from a previous PowerHome upgrade.
Easy enough to fix though. I cant remember if 1.03.4.3 has it or not, but there is most likely a pwrhome.10343.ini file in your PowerHome directory. You can just copy and paste the [WebServer] section from there into your pwrhome.ini file and then try again. Or, Ive included the [WebServer] section for the latest version below (I don't think it changed significantly).
ENABLEWEBSERVER=NO
WEBSERVERPORT=8000
WEBSERVERUSERID=
WEBSERVERPASSWORD=
WEBSERVERDIRECTORY=c:\program files\powerhome\web
WEBSERVERALLOWGUEST=NO
WEBSERVERSECPSP=2
WEBSERVERSECHTM=1
WEBSERVERSECGIF=1
WEBSERVERSECJPG=1
WEBSERVERSECOTHER=1
TRUSTEDIPS=
ENABLESMARTNEXTURL=NO
MAINTITLE=Main
MAINURL=/ph-cgi/main
MENUTITLE1=Control Center
MENUTITLE2=Direct SQL
MENUTITLE3=SQL Query
MENUTITLE4=Event Log
MENUTITLE5=Timed Events
MENUTITLE6=Global Variables
MENUTITLE7=Formula
MENUTITLE8=Uptime
MENUTITLE9=
MENUTITLE10=
MENUTITLE11=
MENUTITLE12=
MENUTITLE13=
MENUTITLE14=
MENUTITLE15=
MENUTITLE16=
MENUTITLE17=
MENUTITLE18=
MENUTITLE19=
MENUTITLE20=
MENUURL1=/ph-cgi/controlcenter?
MENUURL2=/ph-cgi/directsql?
MENUURL3=/ph-cgi/sqlquery?
MENUURL4=/ph-cgi/eventlog?page=1
MENUURL5=/ph-cgi/timedevent?
MENUURL6=/ph-cgi/globalvar?
MENUURL7=/ph-cgi/formula?
MENUURL8=/ph-cgi/uptime
MENUURL9=
MENUURL10=
MENUURL11=
MENUURL12=
MENUURL13=
MENUURL14=
MENUURL15=
MENUURL16=
MENUURL17=
MENUURL18=
MENUURL19=
MENUURL20=
Let me know how it goes,
onhiatus
Posted: May 30 2006 at 12:22 | IP Logged Quote onhiatus
Hey Dave, thanks for the quick response! (as almost always!)
I'll try it out tonight, Tony
