mustangcoupe Super User
Posted: March 31 2006 at 23:59 | IP Logged
Macros from the site wont import into 1.03.4.7.....
Invalid Direct SQL Code -207
SQLSTATE = 21S01
[Sybase][ODBC Driver][Adaptive Server Anywhere]Insert value list does not match column list: Wrong number of values for INSERT
(I was trying to add the et weather macro)
HA newbie
PowerHome - UPB - ELK
Posted: April 01 2006 at 10:39 | IP Logged
Did you try this version?
http://www.power-home.com/download/getweather.txt
I've tweaked it a bit...
http://tonyno.ods.org/ph/getweather2.sql
Gobal variables used: CURTEMP, CURHUMIDITY, CURWINDCHILL, CURFORECAST, TEMP STR.
Also, be sure to change the zip code to your own.
Posted: April 01 2006 at 10:48 | IP Logged
Thanks Tony... those worked... I didnt even know about that txt file... what other samples have been posted ect.. I tried a few more (your ping computer routine) but agian that wont import so I will do it by hand.. but is there a "dump" directory on the website for sql samples?
HA newbie
Posted: April 01 2006 at 11:48 | IP Logged
There are a lot of samples, but no good ways to find them.
This may help.
My ping macro has been improved by the new ph_ping command. I need to post the update.
Posted: April 01 2006 at 11:51 | IP Logged
thanks Tony I did see that post.. and yes please update the ping post we all look up to you and your code samples
HA newbie
Posted: April 01 2006 at 12:40 | IP Logged
Heh! OK, look here!
Posted: April 04 2006 at 09:33 | IP Logged
Tony I dont know if they changed the website again but I get an CURFORECAST Problem getting forecast. response to the variable..
HA newbie
Posted: April 04 2006 at 11:01 | IP Logged
I just checked my system, and it is working. I did modify it for publishing here, so I'll have to check it tonight.
Posted: April 04 2006 at 11:44 | IP Logged
it is not only yours Daves also returns ! to the GV
edit... arrrrg no it is just your code... but for now I can just trweak Daves to pass it to the correct GV and it will do what I want
Edited by mustangcoupe - April 04 2006 at 11:56
HA newbie
Posted: April 08 2006 at 08:16 | IP Logged
That error means the url is incorrect. The macro looks for a 404 coming back from the server.
Posted: April 08 2006 at 14:34 | IP Logged
if I evaluate the first formula I get the following (only partial html shown below) it looks like it is returning an on page...
Formula Evaluation
The formula evaluates to: HTTP/1.1 200 OK
Date: Sat, 08 Apr 2006 18:29:08 GMT
Server: Apache/1.3.33 (Unix) PHP/4.4.0
Cache-control: no-cache, must-revalidate, no-cache="Set-Cookie", private
Expires: Fri, 01 Jan 1990 00:00:00 GMT
Pragma: no-cache
Set-Cookie: DT=1144520948:32249:l3b21; path=/; expires=Fri, 01-Jan-2010 00:00:00 GMT; domain=.weatherunderground.com
Connection: close
Content-Type: text/html
<html>
<head>
<meta http-equiv="Refresh" CONTENT="1800;URL=/cgi-bin/findweather/getForecast?query=031 04">
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
HA newbie
Posted: April 08 2006 at 15:59 | IP Logged
Ah ha! It looks like you have a space in your zip code.
Posted: April 08 2006 at 22:27 | IP Logged
Nope thats not it either.. I dont know how that got there (in the post as it is correct now and I didnt change anything Ive been out all evening)
and the title line shows up correctly see end of post.
hmmm I need to brush up on the ?snap command... and play a bit
Formula Evaluation
Date: Sun, 09 Apr 2006 02:23:06 GMT
Pragma: no-cache
Set-Cookie: DT=1144549386:31306:l3; path=/; expires=Fri, 01-Jan-2010 00:00:00 GMT; domain=.weatherunderground.com
Connection: close
<html>
<head>
<meta http-equiv="pics-label" content='(pics-1.1 "http://www.icra.org/ratingsv02.html" comment "ICRAonline v2.0" l gen true for "http://www.wunderground.com" r (nz 0 vz 0 lz 0 oz 0 cz 0) "http://www.rsac.org/ratingsv01.html" l gen true for "http://www.wunderground.com" r (n 0 s 0 v 0 l 0))'>
<title>Manchester, New Hampshire (03104) Conditions &
edit: It must be something with the forum... as it showed a space agian
Edited by mustangcoupe - April 08 2006 at 22:39
HA newbie
Posted: April 08 2006 at 23:02 | IP Logged
Hmm. I put your zip code in and am getting errors, too...
Posted: April 08 2006 at 23:31 | IP Logged
I guess we dont have weather here... They must reformat the page for diffrent zipcodes. I will hae to parse it for my location and then update the macro.
HA newbie
Posted: April 09 2006 at 10:18 | IP Logged
What I found was that the ph_geturl function was failing (returning a "!"). I saved the page locally, and still get the error loading it. Maybe some code is choking it?
