           | Posted: April 15 2005 at 08:28 | IP Logged
Saw this on another forum.
 15" Dell for $399.
 Ordered one, too, since the price looked so good.
 Tony
           | Posted: April 15 2005 at 14:27 | IP Logged
Thanks Tony...that was a good price.  Ordered mine as well  .
           | Posted: April 19 2005 at 00:50 | IP Logged
Received my unit today. Nice! I spent most of Sunday coding a new front-end for use on it.
 http://tonyno.ods.org/pics/hollytouch-audio.jpg
 It's coming along nicely!
 Also picked up a low-cost, thin (~1/2") VESA mount for it at Radio Shack to hold it until I can flush-mount it.
 Tony
           | Posted: April 19 2005 at 11:18 | IP Logged
Tony, that looks great!  Havent received mine yet.  Not sure if I will get a chance to use it right away.  Building a new house and supposed to close in mid-June.  Lot of home auto related things are on hold until I get moved   .
 Keep us posted on your progress.
         krommetje Super User
           | Posted: April 21 2005 at 07:16 | IP Logged
Hi all
 I've been busy also coding a new frontend for my webinterface... The only thing is that these type of graphics aren't shown correctly in Mozilla and so I've coded it only for IE...
  Edited by krommetje
           | Posted: April 21 2005 at 07:48 | IP Logged
Looks good!
           | Posted: April 21 2005 at 10:27 | IP Logged
Peter,
 That looks great.  Very slick.  It looks like we've got those temperatures working now   .
           | Posted: April 21 2005 at 13:39 | IP Logged
Hi,
 Yeah! It is all working flawlessly now... I had to add the path much sooner to the formula, and I had to upgrade the PC much earlier.... Oh well, that's all water under the bridge now... NEXT PROJECT!
 Peter
           | Posted: April 24 2005 at 19:46 | IP Logged
I just finished cleaning up after mounting the touch screen in my foyer. I couldn't flush-mount it in this location due to conduit in the wall, so, I used a thin (1/2") VESA bracket to attach it to the surface. I'm happy for now.
 Pic 1 • Pic 2
 Next, I need to change up the paint/paper in that area! When I pulled the big mirror down to make room for the screen, there was a nasty halo left behind.
 Since the mirror is gone, and my daughter complained  , I had an idea to add a small web cam on top of the screen and create a "mirror" using it and Webcam2000!
 Tony
           | Posted: April 25 2005 at 01:48 | IP Logged
TonyNo wrote:
       | I just finished cleaning up after mounting the touch screen in my foyer. I couldn't flush-mount it in this location due to conduit in the wall, so, I used a thin (1/2") VESA bracket to attach it to the surface. I'm happy for now. |
 Hey that is looking good. My touch-screen (crt) is at the repairshop because it only shows a horizontal line (hor.sync IC is broke) When it is back I am planning to use it again with an old style 486 with IE on Win95 and place it in the server-room... When I am there I only have to bring the screen up (which I previously made) and can control the whole house from my serverroom....
 Peter
           | Posted: April 25 2005 at 14:39 | IP Logged
 That looks great.  Mine are still in the box   .
 Where is the PC driving the screen?  Did you run a special VGA cable or did you do something like VGA to Cat5 baluns?
           | Posted: April 25 2005 at 15:26 | IP Logged
The PC is hiding around the corner for now (one of those sub-$100 systems I found). I'm thinking about using my HS machine, which is in the basement with USB and VGA extenders, but, I may end up building a bench below the shelf and could stuff a machine in there.
 "Mine are"... How many did you pick up? It was really hard for me to not get two.
 Tony
           | Posted: April 25 2005 at 17:34 | IP Logged
Heh,
 I bought one and then couldnt resist so turned around and bought a second one about 10 minutes later   .
TonyNo wrote:
       | I'm thinking about using my HS machine, |
 What is your "HS" machine...not the dreaded HS is it   ?
  Edited by dhoward
           | Posted: April 25 2005 at 17:55 | IP Logged
Oops! I meant HA! See how close the S is to the A on the keyboard?
 Yeah, the even-lower price they are showing now is very tempting!
 Tony
           | Posted: April 26 2005 at 23:15 | IP Logged
Well, I have progressed further. I can now pull up the Windows On-Screen Keyboard on the touch screen with a button. I ended up running DCC on that machine and use ph_ssrequest to send a ph_run to launch it and a ph_switchto to bring it up if already loaded.
 I also found out that you can increase the width of scroll bars in the Windows Display settings! I spend most of this evening looking for a browser extension that I didn't need!
 Tony
           | Posted: April 29 2005 at 13:30 | IP Logged
Heh, glad you're figuring out these problems for me Tony for when I get around to unboxing mine   .
 I wasnt aware that Windows had an on-screen keyboard.  How do you access this?
           | Posted: April 30 2005 at 11:12 | IP Logged
 Generally, %SystemRoot%\system32\osk.exe...
 Win 2k: \winnt\system32\osk.exe
 Win XP: \WINDOWS\system32\osk.exe
 Also, I needed to add an X-10 filter to the touch screen; seems the power supply eats signals.
 Tony
           | Posted: May 03 2005 at 23:19 | IP Logged
I figured I would post some screen shots of my html/javascript/psp pages that run on the touch screen.
 The pics have been resized from 1024 x 768 x 16b to 640 x 480 x 8b, so, some quality is lost.
         onhiatus Senior Member
           | Posted: May 04 2005 at 17:42 | IP Logged
Tony, thanks for sharing. I'm impressed. I'm trying to figure out how to do most of the same things one a smaller scale - I don't want full size monitors around the house (and the wife wouldn't let me - she already complains about living in a "Harry Potter House")
 I'm hoping to use small 2-4  line serial display panels. I've picked a couple up, just need to get some time to write code...
 Along those lines, does anyone have an elegant way to figure out what is currently playing on Windows Media Player? I should post a new topic in programming for this...
           | Posted: May 04 2005 at 20:45 | IP Logged
Get the Now Playing plugin for WMP. I would suggest using that and scraping the generated HTML for the info.
 I use Winamp with a plugin called Browseamp for control/status.
 Tony
