PhilC Newbie
Online Status: Offline Posts: 39
Posted: February 10 2005 at 19:12 | IP Logged
Hi,
I have a fairly simple question.
I have a 'power on' macro that powers up all my stuff in one go (projector, amp, lights etc).
The problem is if somebody hits the 'power on' button when everything is on already which would actually turn things off.
What I need to do is set a global variable at the start of the macro..ie POWER=ON
...question is, how do I then check to see if POWER=ON or POWER=OFF and quit out of the macro displaying a message box if the POWER=ON or let it continue if POWER=OFF??
many thanks
Phil
Posted: February 10 2005 at 20:04 | IP Logged
If you had a global variable called POWER, you could use this to check it...
if( {POWER}="ON", 999, 1)
If you did a... Set Global | {POWER} | "ON"
This would jump out of the macro when the variable is "ON", and, just drop down to the next line when not.
But, what you have is a feature, not a bug! That same macro can turn off everything, too!
HTH
PhilC Newbie
Posted: February 11 2005 at 06:06 | IP Logged
Thanks Tony,
I have tried that, but the Macro still plays regardless of the value of the variable.
The Macro is:
if("{POWER}"="ON", 999, 1)
ph_setglobal_a( "POWER", "ON" )
--- rest of the macro below ---
Phil
Posted: February 11 2005 at 07:58 | IP Logged
Hmm. That makes no sense. Something else is going on, because what you posted works here.
PhilC Newbie
Posted: February 11 2005 at 08:17 | IP Logged
Very odd. Maybe the clue is in the rest of the macro. It's only a test macro with one extra line which is turning on an amp via IR
Posted: February 11 2005 at 12:15 | IP Logged
Phil,
The only thing that I can think of is to make sure that the if("{POWER}"="ON", 999, 1) is the formula for a macro "Jump" command.
If you can, export the macro and paste the SQL here and we'll get it working for you.
Posted: February 11 2005 at 15:35 | IP Logged
Ah! I would bet that Dave nailed it!
PhilC Newbie
Posted: February 12 2005 at 09:00 | IP Logged
Hi Dave,
macro is:
insert into macroheader values ('TEST','TEST',0,0,1);
insert into macrodetail values ('TEST',1,38,'',0,'if( "{POWER}"="ON", 999, 1) ',0);
insert into macrodetail values ('TEST',2,38,'',0,'ph_setglobal_a( "POWER", "ON" )',0);
insert into macrodetail values ('TEST',3,0,'SWITCHER',4,'',0);
Many thanks
Phil
Posted: February 12 2005 at 10:12 | IP Logged
Ah ha!
The second line of the macro should ba a Jump (16), not a Formula (38).
Tony
PhilC Newbie
Posted: February 14 2005 at 14:52 | IP Logged
Thanks Tony...works fine now!
