PhilC Newbie
Online Status: Offline Posts: 39
| Posted: December 31 2004 at 06:16 | IP Logged
Hi all and Happy holidays,
Is it possible to have the default page (as soon as you log in to the web center) be one of the CCtabs of your choice? ...I have built a tab specifically for use for my smartphone which is low on bandwidth.
Many thanks
Phil
| Posted: December 31 2004 at 09:52 | IP Logged
I think if you set the Tab Order of the tab you want to come up first to the lowest value, and then link to the CC (/ph-cgi/controlcenter?), you should be fine.
| Posted: December 31 2004 at 11:39 | IP Logged
Better yet, you could also call tab directy with this...
/ph-cgi/controlcenter?ID=mytab
where mytab is the id of the appropriate tab.
| Posted: December 31 2004 at 11:44 | IP Logged
Phil,
It's possible. In the PowerHome Explorer, go to Setup->Web. Under the "Main Page" section you can type the URL of the default main page. This may not give you the desired result however so you'll have to play and see if it's what you need. You will need to determine what the URL of the CC tab you want to be the main page. It will probably look something similar to: http://127.0.0.1/ph-cgi/controlcenter?id=QC&type=3&flags=2. Refer to this message for a complete explanation of the web CC's parameters http://www.power-home.com/forum/display_topic_threads.asp?ForumID=1&TopicID=371.
You could also create an index.htm file in the PowerHome web directory and make it a simple HTML file which allows you to choose if you want the standard PH web page or a bandwidth reduced one. By creating this index.htm, you will override the /ph-cgi/main webpage as the default start page without changing how the internal webserver processes.
Hope this helps and Happy New Year.
PhilC Newbie
| Posted: January 02 2005 at 09:45 | IP Logged
Thanks guys, that did the job, however it has hilighted a new problem. My phone (SonyEricsson P900) does not seem to recognise the CC buttons as buttons. In fact it does not seem to understand 'onClick' events at all. So is it possible to create CCbuttons as html links?
Many thanks
Phil
| Posted: January 02 2005 at 11:15 | IP Logged
The CC is coded into PH (no external files besides the stylesheet). I think what you want is only possible if you wrtie your own PSP pages. If you let us know what you want to do, we can get you started.
PhilC Newbie
| Posted: January 02 2005 at 15:58 | IP Logged
Thanks Tony. I have worked out how to code the psp pages, trouble is whenever I execute a command, I am always forwarded on to the main web center screen. For example a simple button to turn on the hall lights:
<form method="get" action="/ph-cgi/x10">
<input type="hidden" name="hc" value="A">
<input type="hidden" name="uc" value="9">
<input type="submit" name="cmd" value="ON">
<input type="submit" name="cmd" value="OFF">
</form>
This works fine on a normal browser but on a non-frames compatible, it forwards me on to the main screen. Any ideas how to get around this?
Many thanks
Phil
| Posted: January 02 2005 at 16:44 | IP Logged
Sure. I think all you need to do is add this to your form def...
<input type="hidden" name="nexturl" value="/yourpage.psp">
krommetje Super User
| Posted: January 04 2005 at 07:31 | IP Logged
</form>
Many thanks
Phil
Hi Phil,
With this message I was able to make a low-res page which controls my frontdoor shutter:
here's the code:
<html>
<head>
<title>X-10 Control Panel</title>
</script>
</head>
<body bgcolor=whitesmoke text=black link=blue vlink=blue alink=blue>
<center>
<table border=4 cellpadding=1 cellspacing=2>
<tr bgcolor=navy><td nowrap>
<table border=0 width="100%"cellpadding=0 cellspacing=0><tr>
<td nowrap><img src= "imgicon.gif">
<td nowrap><font face="MS Sans Serif" color=white size=2><b>X-10 Control Panel</b></td>
<td nowrap align=right><img src= "imgx.gif">
</tr></table>
</td></tr>
<tr bgcolor=silver><td>
</td></tr>
</table>
</center>
<p>
<center>
Frontdoor Shutter:
<input type="hidden" name="hc" value="K">
<input type="hidden" name="uc" value="4">
</form>
</center>
</body>
</html>
Testing was successfull so this little page works:
The only disadvantage is that after the command is executed, like you mentioned in your original post, the main-page automaticly executes....which is too big for a Mobile-Phone or I-Mode-Phone
Any Ideas to solve this?
Peter
PhilC Newbie
| Posted: January 04 2005 at 07:40 | IP Logged
Hi Peter,
If you put:
<input type="hidden" name="nexturl" value="yourpage.html">
within the form, it will refresh to whatever page you specify in 'yourpage.html'
That worked for me.
Phil
| Posted: January 04 2005 at 13:45 | IP Logged
I'll also look into adding an option for replacing the "onclick" with HTML links for the web CC.
| Posted: January 05 2005 at 04:02 | IP Logged
That worked for me.
i'll update the code asap, btw, have you been able to run this type of low-res pages on your smartphone yet?
Peter
