Lenny Senior Member
Posted: May 21 2014 at 16:24 | IP Logged
Ok, Awhile back before MS EOL'd Windows XP I built new PH
Server. Windows 7, installed to c:\powerhome, applied the
2.1.4 I2CS patch, & disabled UAC. Everything seemed fine.
Later I brought one of my old remotelinc's back into
service and created a couple links and noticed the PLM
links always stayed Flagged Create. Nothing I did would
make it change to verified. Clear Failed, Coms, disabled,
enabled. Everything works fine with the remote. I just
wrote it off as something with the remotelinc.
Now, My PLM died and I got replacement. I did the replace
address process, it deleted links and recreated without a
single nak. Everything works fine... however now every
PLM link shows "flagged create". Now, i'm thinking
something is corrupt in my db.
Anyone have any thoughts? I see 2.1.5 is moving along.
I'm thinking I probably should get this resolved before I
upgrade to that when its available.
Thanks guys.
Lenny
Posted: May 27 2014 at 15:22 | IP Logged
Lenny,
Try running the two SQL commands in my post here: http://www.power-home.com/forum/forum_posts.asp?TID=3230&PN= 2&get=last. That should clear it up.
Let me know,
Lenny Senior Member
Posted: May 27 2014 at 19:36 | IP Logged
That took care of it Dave. Thanks so much. Look forward to
the next release.
Lenny Senior Member
Posted: May 29 2014 at 18:33 | IP Logged
Well, I thought I was OK. All my pending links are fine
now however I'm sure my NEW PLM is i2cs and is causing
powerhome not to update the status. All my other devices
are older.
I have cleared the PLM and done an Add Full. To be honest
I don't totally understand how this is used by the PLM or
powerhome.
From what I have read in other posts the new protocol
requires a link to the PLM.
I have 3 PLM groups that every device are members.
Downstairs, Upstairs & ALL Lights. Each switch is a
member of of 2 of the 3 groups. Maybe this isn't
considered a link in the i2cs protocol.
From PH, I can control the light on and off with no
problem. But the status doesn't update when I use the
physical switch.
As a test I created a link on a switch with the PLM as a
responder. Tested the switch and PH didn't see the status
change. I then did Clear PLM and Add Full and now the
status updates.
So, I guess I have a few questions.
1 - Whenever I make any link changes should I clear the
PLM and ADD FULL?
2 - What link is required for Powerhome to see the status
change?
3 - Buttons and Groups when linking still kind of confuse
me. I put Insteon in my entire house when I bought it in
2006 and have 450+ links, I should know by now. In the
attached screenshot, looking at the garage_keypad, the
2nd link. The group 2 in orange refers to the 2nd button
in the MediaRM keypad and Button 4 in yellow refers to
the 4th button in the garage_keypad. The first link is
part of the same "scene" so, the group 1, refers to the
basement light switch and button 4 refers to the same
button 4 on the garage_keypad... This is the way I have
always interpreted it. Is their any easier way to think
about this? It's rare I make any changes so when I do, I
have to stop and wake my brain up again.
Sorry, Chrome didn't upload the image... IE worked.
Thanks again guys!
Edited by Lenny - May 29 2014 at 18:38
