Subject Topic: How do i get address of unlabeled cntrlr? Post ReplyPost New Topic
jeffw_00
Posted: March 08 2013 at 16:37 | IP Logged Quote jeffw_00
I just inherited a used Controlinc. The address label fell off. I could probably figure this out with time, but is there an easy trick to determining the address using PH?
jeffw_00
Posted: March 08 2013 at 16:52 | IP Logged Quote jeffw_00
answer - put the device in linking mode, do a manual link, and then loo at PH status.
(how do I delete the link, or do I have to?)
Posted: March 10 2013 at 21:23 | IP Logged Quote dhoward
Jeff,
Another option is to place PH in "Auto Discovery" (Setup tab of Insteon Explorer) and then place the ControLinc into Link mode. Right after hitting entering link mode, take the CL out of link mode. Back at PH, you should see the address in the Log window of the Setup tab and you should have a new device auto created for you in the Devices tab (NEW DEVICE XX). You can now just rename the new device to match your CL.
jeffw_00
Posted: March 11 2013 at 08:00 | IP Logged Quote jeffw_00
thanks!
