         traviskleckner Senior Member
           | Posted: January 30 2013 at 07:42 | IP Logged
I've been purchasing a number of I2CS devices lately,
 notably a FanLinc and a KeypadLinc to control it.  I
 thought maybe that HomeLinc would allow me to get some of
 the programming done on the Keypad before the arrival of
 the new PH version.
 So, in messing around with it I added most of my devices
 to HL, but didn't change anything.  Then, on one keypad
 (an old one that was programmed with PH) I adjusted the
 brightness from HL and I somehow broke the links and
 button config.  I assume that when HL wrote to it that's
 what messed it up.  But I wouldn't think that would
 affect the links...but oh, did it ever.
 So I removed it from HL and tried to fix the button
 config with PH.  But it seems like links that I didn't
 think should be changed suddenly didn't work.  I ended up
 removing all the links and re-adding them again with PH
 and everything works as it should.
 I've seen stuff about peek/poke stuff on here, so I'm
 wondering if that's what happened.  If programming with
 HL and PH (different PLMs for what it's worth) on the
 same device a no no?
           | Posted: January 30 2013 at 19:01 | IP Logged
An I2CS device will not respond to a PLM it has not been linked with.  Part of the I2CS protocol changes.  The physical link records are not changed with I2CS.  Only that an I2CS device will not respond to a PLM that has not been linked with it.  Part of the security of I2CS that prevents someone from manipulating devices using an unknown PLM.  AN I2CS device will respond to two PLMs that have been linked with the respective device.
 Perhaps answer is a little redundant but tried to cover what I thought might be follow up questions.
           | Posted: February 15 2013 at 14:26 | IP Logged
Not that it matters, after a little more testing this is
 what I have discovered...on *SOME* KPLs, I had a variety
 of inter button linking.  That is say, button 8 might be
 all off and would turn off the buttons 2, 3 and 4.  There
 there also links associated to those other buttons.  All
 created in PH.  When I edited those KPLs in Home Link it
 killed some of the interbutton linking.  It also jacked
 up some of the links.  PH still shows them (of course, as
 that's PH's internal DB) but when you verify them they
 aren't there.  The only way to fix them seems to be to
 remove them and then recreate them.  I've tested and I
 can re-create the problem, but only on some KPLs.  The
 really old KPLs seem to be fine.  It's the firmware that
 allows you to alter the LED brightness that's an issue.
 Anywho, the net of what I've discovered is that HL sucks
 and I really want the newer I2CS version of PH.
