         benjip37 Newbie
           | Posted: January 23 2013 at 18:31 | IP Logged
PowerHome says it requires a 32-bit version of windows vista. Will it work on
 a 64-bit version of windows 8. Sorry if this is a stupid question. I don't know
 too much about that kind of stuff.
           | Posted: January 23 2013 at 23:30 | IP Logged
Ben,
 PowerHome can run on 64 bit systems without issue.  I
 know of users who have used XP, Vista, and Win 7 all 64
 bit versions without a problem.  Several users are using
 PowerHome on Windows 8 without issue but Im note sure if
 they're using 32 or 64 bit.
 Best thing to do would be to try it out and report back
 any issues you may have.  It should work without a
 problem but until someone actually tries it I cant say
 for sure.  Your best bet would be to install the 2.1.4
 beta as this is more compatible with the newer OS'es.
           | Posted: January 24 2013 at 08:11 | IP Logged
I use on all above. My online system is win8 64x
