         Steve W Newbie
           | Posted: February 19 2011 at 02:24 | IP Logged
Hi,
 I've been away a while and am getting back into the insteon controllers and such.
 So far I've downloaded 2.1.2 to my new computer and hooked up my old 2414u to it.  Windows 7 saw it and installed something, but it happened so fast I'm not sure what driver it installed.
 When I try to get PH2 going I'm getting an error related to "ISRESPONDING".  As in, my 2414u is not.
 I went into the setup - controller menu and made it an Insteon DM.
 Where do I go from here?
 Steve
           | Posted: February 19 2011 at 07:05 | IP Logged
Not sure if both are necessary so I would install 2.1.3 which is just unzipping a file over the 2.1.2 and then 2.1.4 which is another ZIP file to be unzipped over 2.1.3.  There is an issue at 2.1.2 where the SDM3 interface to the 2414 PLC was not being used correctly.  2.1.3 ZIP file fixes that problem and then there is another 2.1.4 ZIP file with another fix.
 Follow the posts under 2.1.2.  There are links to 2.1.3 ZIP and 2.1.4 ZIP files in subsequent posts to the 2.1.2 announcement.
  Edited by grif091 - February 19 2011 at 07:08
           | Posted: February 19 2011 at 07:19 | IP Logged
Lee,
 213 has the fix for the PLC. Had the problem myself.
           | Posted: February 19 2011 at 07:31 | IP Logged
Thanks Pete.   Was not sure if 2.1.4 ZIP is cumulative, containing both the 2.1.3 PLC fix and the 2.1.4 fix for something else.  Might be 2.1.4 ZIP is all that is needed if it is cumulative.  Figured installing both could not hurt just in case 2.1.4 does not contain the 2.1.3 PLC fix.
         Steve W Newbie
           | Posted: February 19 2011 at 10:39 | IP Logged
I downloaded 213 and 214.  I hit extract all and directed into the C:\powerhome directory.
 I'm still getting the error.
 Did I install it wrong?
 Any other things I can try?
         Steve W Newbie
           | Posted: February 19 2011 at 10:48 | IP Logged
Windows did install it as a Human interface device.
 There are no drivers loaded for it when I look at its properties.
 Should the SDM be loaded as its driver?
         Steve W Newbie
           | Posted: February 19 2011 at 11:31 | IP Logged
Just found a bug report in the smarthome/device manager folder.  Cannot get the SDM3 started from that folder either.
 date/time         : 2011-02-19, 10:28:22, 527ms
 computer name     : CYBERPOWER
 user name         : Family
 operating system  : Windows NT New build 7600
 system language   : English
 system up time    : 33 minutes 47 seconds
 program up time   : 46 milliseconds
 processors        : 8x Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
 physical memory   : 4760/6135 MB (free/total)
 free disk space   : (C:) 894.68 GB
 display mode      : 1920x1080, 32 bit
 process id        : $1294
 allocated memory  : 16.39 MB
 executable        : sdm3.exe
 exec. date/time   : 2006-12-05 19:43
  version          ;  : 1.1.138.308
 madExcept version : 3.0b
 callstack crc     : $715b2c21, $b0caba1a, $b0caba1a
  count         & nbsp;   : 34
 exception number  : 1
 exception class   : EOleSysError
 exception message : Error accessing the OLE registry.
 main thread ($2e4):
 004c099c  sdm3.exe     ComObj  &nbs p;    OleError
  004c09b4  sdm3.exe     ComObj  &nbs p;    OleCheck
  005fff07  sdm3.exe     ComServ  &nb sp;   RegisterTypeLibrary
  006005a9  sdm3.exe     ComServ  &nb sp;   TComServer.UpdateRegistry
  00600441  sdm3.exe     ComServ  &nb sp;   TComServer.Initialize
  00600631  sdm3.exe     ComServ  &nb sp;   InitComServer
  004a3a8b  sdm3.exe     Forms    ;6950 TApplication.Initialize
 0065e73b  sdm3.exe     SDM3       73 initialization
 76643675  kernel32.dll               BaseThreadInitThunk
 modules:
 00400000  sdm3.exe       1.1.138.30 8      C:\powerhome\SmartHome\ device manager
 6b250000 mpr.dll        6.1.7600.16385   C:\Windows\system32
 6e120000  olepro32.dll   6.1.7600.16385  &nbs p;C:\Windows\system32
 715c0000  uxtheme.dll    6.1.7600.16385   ; C:\Windows\system32
 71640000 SXS.DLL        6.1.7600.16385   C:\Windows\system32
 71920000 comctl32.dll   5.82.7600.16661   C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595 b64144ccf1df_5.82.7600.16661_none_ebfb56996c72aefc
  73740000  version.dll    6.1.7600.16385   ; C:\Windows\system32
 73860000  wsock32.dll    6.1.7600.16385   ; C:\Windows\system32
 74b10000  dwmapi.dll     6.1.7600.16385    C:\Windows\system32
  74e10000 CRYPTBASE.dll  6.1.7600.16385   C:\Windows\syswow64
 74e20000  SspiCli.dll    6.1.7600.16484   ; C:\Windows\syswow64
 74e80000  wininet.dll    8.0.7600.16723   ; C:\Windows\syswow64
 74f80000  ADVAPI32.dll   6.1.7600.16385  &nbs p;C:\Windows\syswow64
 75020000  MSASN1.dll     6.1.7600.16415    C:\Windows\syswow64
  75030000 NSI.dll        6.1.7600.16385   C:\Windows\syswow64
 75050000  shell32.dll    6.1.7600.16644   ; C:\Windows\syswow64
 75ca0000 KERNELBASE.dll 6.1.7600.16385   C:\Windows\syswow64
 75cf0000  urlmon.dll     8.0.7600.16723    C:\Windows\syswow64
  75e30000  comdlg32.dll   6.1.7600.16385  &nbs p;C:\Windows\syswow64
 76050000  USP10.dll      1.626.7600.1638 5 C:\Windows\syswow64
 760f0000  MSCTF.dll      6.1.7600.16385& nbsp;  C:\Windows\syswow64
  76250000  iertutil.dll   8.0.7600.16722  &nbs p;C:\Windows\syswow64
 76460000  msvcrt.dll     7.0.7600.16385    C:\Windows\syswow64
  76510000  sechost.dll    6.1.7600.16385   ; C:\Windows\SysWOW64
 76530000  user32.dll     6.1.7600.16385    C:\Windows\syswow64
  76630000  kernel32.dll   6.1.7600.16385  &nbs p;C:\Windows\syswow64
 76730000  CRYPT32.dll    6.1.7600.16385   ; C:\Windows\syswow64
 76850000  SHLWAPI.dll    6.1.7600.16385   ; C:\Windows\syswow64
 76990000  WS2_32.dll     6.1.7600.16385    C:\Windows\syswow64
  769d0000  IMM32.DLL      6.1.7600.16385& nbsp;  C:\Windows\system32
  76a90000  oleaut32.dll   6.1.7600.16567  &nbs p;C:\Windows\syswow64
 76b20000  GDI32.dll      6.1.7600.16385& nbsp;  C:\Windows\syswow64
  76bd0000  RPCRT4.dll     6.1.7600.16385    C:\Windows\syswow64
  76cf0000  ole32.dll      6.1.7600.16624& nbsp;  C:\Windows\syswow64
  77280000 LPK.dll        6.1.7600.16385   C:\Windows\syswow64
 772b0000  ntdll.dll      6.1.7600.16695& nbsp;  C:\Windows\SysWOW64
 processes:
 0000  Idle         &n bsp;         &n bsp;     0
  0004  System                         0
 0130  smss.exe        &nbs p;         &nbs p;  0
 01b4  csrss.exe        &nb sp;         &nb sp; 0
 01fc  wininit.exe        & nbsp;         0
 0214  csrss.exe        &nb sp;         &nb sp; 1
 0234  services.exe                  0
  0248  lsass.exe        &nb sp;         &nb sp; 0
 0250  lsm.exe          ;           ;   0
 02b0  winlogon.exe                  1
  02f8  svchost.exe        & nbsp;         0
 0348  svchost.exe        & nbsp;         0
 0388  atiesrxx.exe                  0
  03c4  svchost.exe        & nbsp;         0
 03f0  svchost.exe        & nbsp;         0
 00a0  svchost.exe        & nbsp;         0
 0358  svchost.exe        & nbsp;         0
 0438  atieclxx.exe                  1
  045c  svchost.exe        & nbsp;         0
 0510  spoolsv.exe        & nbsp;         0
 052c  svchost.exe        & nbsp;         0
 0574 AppleMobileDeviceService.exe 0
 0598  mDNSResponder.exe       & nbsp;    0
  05c4  svchost.exe        & nbsp;         0
 05f4  SeaPort.exe        & nbsp;         0
 0664  WLIDSVC.EXE        & nbsp;         0
 0744  taskhost.exe                  1  normal
 07a4  WLIDSVCM.EXE                  0
  08a8  svchost.exe        & nbsp;         0
 08dc  WUDFHost.exe                  0
  0934  dwm.exe          ;           ;   1 high
 094c  explorer.exe                  1  normal
 09ac  RAVCpl64.exe                  1  normal
 0a28  iTunesHelper.exe       &n bsp;     1  normal C:\Program Files (x86)\iTunes
 0a50  MOM.exe          ;           ;   1 normal
 0bbc  CCC.exe          ;           ;   1 normal
 0990  iPodService.exe       &nb sp;      0
  091c  SearchIndexer.exe       & nbsp;    0
  07cc  wmpnetwk.exe                  0
  0d20  svchost.exe        & nbsp;         0
 0dd8 PresentationFontCache.exe    0
 0b0c  dllhost.exe        & nbsp;         0
 0160  mscorsvw.exe                  0
  0684  mscorsvw.exe                  0
  0cb0  svchost.exe        & nbsp;         0
 0f58  taskhost.exe                  1
 0ae4  wlmail.exe        &n bsp;         &n bsp;1 normal C:\Program Files (x86)\Windows Live\Mail
 0628  wlcomm.exe        &n bsp;         &n bsp;1 normal C:\Program Files (x86)\Windows Live\Contacts
 07e4  iexplore.exe                  1  normal C:\Program Files (x86)\Internet Explorer
 0518  iexplore.exe                  1  normal C:\Program Files (x86)\Internet Explorer
 0f3c  SCServer.exe                  1  normal C:\Program Files (x86)\Microsoft\Search Enhancement Pack\SCServer
 09a0  splwow64.exe                  1  normal
 13d0  audiodg.exe        & nbsp;         0
 11d0  iexplore.exe                  1  normal C:\Program Files (x86)\Internet Explorer
 133c FlashUtil10m_ActiveX.exe     1 normal C:\Windows\SysWOW64\Macromed\Flash
 0a94  dllhost.exe        & nbsp;         1  normal
 1294  sdm3.exe        &nbs p;         &nbs p;  1 normal C:\powerhome\SmartHome\device manager
 hardware:
 + Computer
   - ACPI x64-based PC
 + Disk drives
   - Canon iP6000DStorage USB Device
   - Hitachi HDS721010CLA332 ATA Device
 + Display adapters
   - ATI Radeon HD 5700 Series (driver 8.821.0.0)
 + DVD/CD-ROM drives
   - ATAPI iHAS124   B ATA Device
 + Human Interface Devices
   - HID-compliant consumer control device
   - HID-compliant device
   - USB Input Device
   - USB Input Device
   - USB Input Device
 + IDE ATA/ATAPI controllers
   - ATA Channel 0
   - ATA Channel 0
   - ATA Channel 0
   - ATA Channel 1
   - ATA Channel 1
   - ATA Channel 1
   - Intel(R) ICH10 Family 2 port Serial ATA Storage Controller 2 - 3A26 (driver 9.1.1.1013)
   - Intel(R) ICH10 Family 4 port Serial ATA Storage Controller 1 - 3A20 (driver 9.1.1.1013)
   - Standard Dual Channel PCI IDE Controller
 + IEEE 1394 Bus host controllers
   - 1394 OHCI Compliant Host Controller
 + Keyboards
   - Standard PS/2 Keyboard
 + Mice and other pointing devices
   - HID-compliant mouse
 + Monitors
   - Generic PnP Monitor
 + Network adapters
   - Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20)
 + Portable Devices
   - E:\
 + Ports (COM & LPT)
   - Communications Port (COM1)
 + Printers
   - Canon Inkjet PIXMA iP6000D (driver 6.1.7233.0)
 + Processors
   - Intel(R) Core(TM) i7 CPU         950  @ 3.07GHz
 + Sound, video and game controllers
   - AMD High Definition Audio Device (driver 7.12.0.7700)
   - Realtek High Definition Audio (driver 6.0.1.6069)
 + Storage volume shadow copies
   - Generic volume shadow copy
 + System devices
   - ACPI Fixed Feature Button
   - ACPI Power Button
   - Composite Bus Enumerator
   - Direct memory access controller
   - File as Volume Driver
   - High Definition Audio Controller
   - Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405 (driver 9.1.1.1026)
   - Intel(R) 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423 (driver 9.1.1.1026)
   - Intel(R) 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422 (driver 9.1.1.1026)
   - Intel(R) 7500/5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408 (driver 9.1.1.1026)
   - Intel(R) 7500/5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A (driver 9.1.1.1026)
   - Intel(R) 7500/5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E (driver 9.1.1.1026)
   - Intel(R) 7500/5520/5500/X58 I/O Hub System Management Registers - 342E (driver 9.1.1.1026)
   - Intel(R) 7500/5520/5500/X58 I/O Hub Throttle Registers - 3438 (driver 9.1.1.1026)
   - Intel(R) 82801 PCI Bridge - 244E
   - Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
   - Intel(R) ICH10 Family PCI Express Root Port 2 - 3A42
   - Intel(R) ICH10 Family PCI Express Root Port 5 - 3A48
   - Intel(R) ICH10 Family PCI Express Root Port 6 - 3A4A
   - Intel(R) ICH10 Family SMBus Controller - 3A30
   - Intel(R) ICH10R LPC Interface Controller - 3A16
   - Microsoft ACPI-Compliant System
   - Microsoft System Management BIOS Driver
   - Microsoft Virtual Drive Enumerator Driver
   - Microsoft Windows Management Interface for ACPI
   - Motherboard resources
   - Numeric data processor
   - PCI bus
   - Plug and Play Software Device Enumerator
   - Programmable interrupt controller
   - System board
   - System board
   - System CMOS/real time clock
   - System speaker
   - System timer
   - Terminal Server Keyboard Driver
   - Terminal Server Mouse Driver
   - UMBus Enumerator
   - UMBus Enumerator
   - UMBus Root Bus Enumerator
   - Volume Manager
 + Universal Serial Bus controllers
   - Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
   - Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
   - Intel(R) ICH10 Family USB Universal Host Controller - 3A34
   - Intel(R) ICH10 Family USB Universal Host Controller - 3A35
   - Intel(R) ICH10 Family USB Universal Host Controller - 3A36
   - Intel(R) ICH10 Family USB Universal Host Controller - 3A37
   - Intel(R) ICH10 Family USB Universal Host Controller - 3A38
   - Intel(R) ICH10 Family USB Universal Host Controller - 3A39
   - USB Composite Device
   - USB Mass Storage Device
   - USB Printing Support
   - USB Root Hub
   - USB Root Hub
   - USB Root Hub
   - USB Root Hub
   - USB Root Hub
   - USB Root Hub
   - USB Root Hub
   - USB Root Hub
 cpu registers:
 eax = 02e7aa74
 ebx = 8002801c
 ecx = 00000001
 edx = 004c09a1
 esi = 02e7a29c
 edi = 6d01ae5c
 eip = 004c09a1
 esp = 0018fea8
 ebp = 0018ff08
 stack dump:
 0018fea8  a1 09 4c 00 de fa ed 0e - 01 00 00 00 07 00 00 00  ..L.............
 0018feb8  bc fe 18 00 a1 09 4c 00 - 74 aa e7 02 1c 80 02 80  ......L.t.......
 0018fec8  9c a2 e7 02 5c ae 01 6d - 08 ff 18 00 d8 fe 18 00  ....\..m........
 0018fed8  1c 80 02 80 b9 09 4c 00 - 5c 93 e7 02 0c ff 5f 00  ......L.\....._.
 0018fee8  10 ff 18 00 d4 46 40 00 - 08 ff 18 00 01 00 00 00  .....F@.........
 0018fef8  00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
 0018ff08  28 ff 18 00 ae 05 60 00 - 30 ff 18 00 d4 46 40 00  (.....`.0....F@.
 0018ff18  28 ff 18 00 39 1e 00 00 - f0 05 60 00 00 00 00 00  (...9.....`.....
 0018ff28  4c ff 18 00 46 04 60 00 - 64 ff 18 00 50 04 60 00  L...F.`.d...P.`.
 0018ff38  4c ff 18 00 5c ae 01 6d - 39 1e 00 00 f0 05 60 00  L...\..m9.....`.
 0018ff48  9c a2 e7 02 70 ff 18 00 - 36 06 60 00 8d 3a 4a 00  ....p...6.`..:J.
 0018ff58  00 00 40 00 40 e7 65 00 - 00 44 6e 00 c4 ff 18 00  ..@.@.e..Dn.....
 0018ff68  04 49 40 00 70 ff 18 00 - 00 00 00 02 94 ff 18 00  .I@.p...........
 0018ff78  8c ff 18 00 00 e0 fd 7e - 00 10 40 00 00 00 00 00  .......~..@.....
 0018ff88  65 36 64 76 77 36 64 76 - 00 e0 fd 7e d4 ff 18 00  e6dvw6dv...~....
 0018ff98  02 9f 2e 77 00 e0 fd 7e - 03 30 3d 77 00 00 00 00  ...w...~.0=w....
 0018ffa8  00 00 00 00 00 e0 fd 7e - 00 00 00 00 00 00 00 00  .......~........
 0018ffb8  00 00 00 00 a0 ff 18 00 - 00 00 00 00 ff ff ff ff  ................
 0018ffc8  e5 0a 32 77 87 0a 08 00 - 00 00 00 00 ec ff 18 00  ..2w............
 0018ffd8  d5 9e 2e 77 00 10 40 00 - 00 e0 fd 7e 00 00 00 00  ...w..@....~....
 disassembling:
 004c098c   push    0
  004c098e   xor     e cx, ecx
  004c0990   mov     d l, 1
  004c0992   mov     e ax, [$4bec6c]
 004c0997   call    -$17c ($4c0820)        ; ComObj.EOleSysError.Create
 004c099c > call    -$bc201 ($4047a0)      ; System.@RaiseExcept
  004c09a1   pop     e bx
 004c09a2   ret
           | Posted: February 19 2011 at 15:40 | IP Logged
There was a time when Smartlabs indicated the SDM3 was not compatible with W7 64 bit.  Cannot find that documented any more.  Cannot find any statement about the environments SDM3 supports.  Unless someone has used SDM3 in a 64 bit configuration I have to wonder if that environment is supported.  It may be by now.  Suggest a call to Smarthome support.
           | Posted: February 20 2011 at 08:06 | IP Logged
I run my PLC on Win 7 64bit. SDM is not a driver but an application that acts like a driver. Try launching SDM without PH. Powerhome/Smarthome/device manager/SDM3. Click on the window type DM. In the next windows type isresponding. Also type getport and make sure you have the correct port in PH controller settings. Report back what you find.
           | Posted: February 21 2011 at 11:48 | IP Logged
Steve,
 Make sure that on Windows 7 you've installed into c:\powerhome vs c:\program files\powerhome.  Since you're on 2.1.2, you're probably already good here since that is the default location.
 You also must right-click on SDM3.exe and set it to XP compatibility mode and run as administrator.  Once you've done that, launch SDM3.exe (without PH running) and see if it will connect to your PLC.  If you get this far, you should be able to launch PH and have it work.
