Subject Topic: CM11A no communicate... sort of Post ReplyPost New Topic
Gadgets
Posted: September 04 2010 at 22:46 | IP Logged Quote Gadgets
I started a new topic for easier searching down the road should someone have this problem.
I was thinking my CM11a had finally died, however it's not dead... at least not completely. Here's what's going on.
I tested the communications between the PowerHome computer and the CM11a (they are not in the same room). I opened the multi-editor and used this formula:
ph_connect(main) where "main" is the name of the CM11a.
It returns the following:
Formula Evaluation
Execution time: 0.000 seconds.
The formula evaluates to:!
Clearly it is not connecting (or I'm entering the incorrect formula). HOWEVER, if I send any commands to X10 devices from other controllers, and palm pads the event log shows them correctly. Buuut, if I use PH to send a command the event log shows them, but nothing happens to the module(s) the command was sent to.
I'm starting to wish I didn't finally have some time to work on this stuff.
Now I don't know if the CM11a is working or not!!!
Friends, don't let friends install Norton Products
Back to Top View Gadgets's Profile Search for other posts by Gadgets Visit Gadgets's Homepage
Posted: September 09 2010 at 16:08 | IP Logged Quote dhoward
Formula is wrong. A return value of "!" indicates a syntax error. In this case, if your CM11A controller has an ID of MAIN on the Controllers screen of the PowerHome Explorer, the correct syntax should be:
ph_connect("MAIN")
Need either single or double quotes around a string and it should be capitalized (although lower case will work, a future upgrade to the database..beyond my control..may enforce proper case).
You can check if PowerHome is at least properly recognizing your any of your connected controllers by going to Help|About|Controllers.
