| Posted: January 10 2004 at 22:10 | IP Logged
After looking at the link provided, it appears that the IR transceiver is interfaced with the serial port and as such is meant to send and receive commands from a PC wirelessly.  These types of signals would not be compatible with the IR which is associated with the control electronic equipment.
Most consumer IR is of a pulse width modulation nature with a carrier frequency around 38Khz.  The type of IR used in serial communications is typically of an IRDA nature with the two being incompatible  .
Sorry,
