Subject Topic: Can I connect with a 2414U Post ReplyPost New Topic
theedudenator
Posted: November 09 2009 at 21:44 | IP Logged Quote theedudenator
I downloaded the trial version and am trying to see how it works.
I currently have a 2414U.
I am not sure what settings to use. I tried both on the list and I get lots of errors...
Back to Top View theedudenator's Profile Search for other posts by theedudenator
grif091
Posted: November 09 2009 at 22:37 | IP Logged Quote grif091
The 2414U is a USB PLC. Powerhome supports that device per the following from Features list...
"Insteon control using USB or Serial PowerLinc V2 and the SmartHome Device Manager."
Under Powerhome Explorer/Setup/Controllers/ the Controller Type is Insteon DM. I used a Serial PLC for several months before moving to a PLM. What messages are you receiving?
Lee G
theedudenator
Posted: November 13 2009 at 22:29 | IP Logged Quote theedudenator
DEVICE MANAGER ISRESPONDING COMMAND FAILED FOR INSTEON PLC USB ATTEMPTING TO RESTART CONTROLLER.
In the smarthomes device manager "FIND PLC"
It shows USB4
I have the controller in PH as insteon DM
grif091
Posted: November 13 2009 at 23:39 | IP Logged Quote grif091
After PH has started there will be a blue T shaped Icon in the system tray representing the Smartlabs SDM3 device manager. Double click on the T Icon to open the SDM3 window. Type dm which will open a command line at the bottom of the window. In the command line type isresponding and hit enter. The response should be true if the SDM3 is able to communicate with the PLC.
Lee G
theedudenator
Posted: November 14 2009 at 10:06 | IP Logged Quote theedudenator
PLC:isresponding=True
uifinished:isresponding
This is what I get.
This also works fine in Homeseer.
So I think it is software not hardware
grif091
Posted: November 14 2009 at 10:25 | IP Logged Quote grif091
In the powerhome/smarthome subdirectory there are two bat files, 235.bat and 308.bat. These bat files establish which version of sdm3 will be used.   You can tell from the file size of SDM3.exe compared to SDM3.exe.235 or SDM3.exe.308 which level SDM3 is currently being used by Powerhome. You can try running the opposite xxx.bat file to see if a different level SDM3 works any better. I ran the 308 level when using my serial PLC.
Lee G
BeachBum
Posted: November 14 2009 at 13:23 | IP Logged Quote BeachBum
See if you can type in “getlinks” in the DM window and you should see the links being built. And finally you could do a hard reset on the PLC and see what that produces.
Edited by BeachBum - November 14 2009 at 13:35
Pete - X10 Oldie
theedudenator
Posted: November 17 2009 at 19:54 | IP Logged Quote theedudenator
Getlinks shows the links being built.
I am not sure how to do a hard reset.
I am using ver SDM3 308
BeachBum
Posted: November 17 2009 at 23:18 | IP Logged Quote BeachBum
Well, I wonder maybe everything is working and you had a false startup message. Have you tried anything else? You do a hard reset by holding the button for 10 seconds or more as you plug it back in. But then you should follow it by a download min.
Pete - X10 Oldie
