Subject Topic: Getting started with formulas/triggers Post ReplyPost New Topic
sarcophage
Posted: July 20 2009 at 09:22 | IP Logged Quote sarcophage
Good morning, all -
I've just recently downloaded PowerHome2, and am really
excited about its extensibility and the already great set
of features it includes out of the box!
having said that, I am having a lot of trouble
understanding the differences between
macros/triggers/formulas, and how to implement them.
For example, if I wanted to code a motion sensor to flash
a lamplinc for 2 seconds, where would I even begin? I've
searched the wiki and the quick start, and neither have
quite given me the solution I'm looking for.
thanks in advance!
Back to Top View sarcophage's Profile Search for other posts by sarcophage
grif091
Posted: July 20 2009 at 13:15 | IP Logged Quote grif091
A Trigger fires when a particular event occurs. In this case you would define a Trigger to fire when the Motion Sensor sends a Group 1 ON message sequence to the PH2 PLM/PLC.   This requires the Motion Sensor be linked as a Controller with the PH2 PLM/PLC as a responder. The motion sensor link must be started manually as the motion sensor does not support the Peek/Poke commands normally used by PH2 (and other apps) to write link records.
The Trigger can perform various things but I would suggest defining it to invoke a Macro when the trigger fires. Within the Macro you can code an Insteon command to turn ON then OFF the LampLinc. A Trigger can perform PH functions but there are issues with a Trigger issuing Insteon commands so the Macro is the better option.
EDIT: the following topic describes a Trigger for a Motion Sensor low battery. Change the Group to 1 for motion.
Link to Motion Sensor Trigger
Edited by grif091 - July 20 2009 at 13:22
Lee G
Posted: July 20 2009 at 14:33 | IP Logged Quote TonyNo
You may also want to look at a tutorial I did a ways back. It's for X10, but the concepts are the same for any other technology.
Getting Started with Formulas and Triggers
sarcophage
Posted: July 21 2009 at 14:11 | IP Logged Quote sarcophage
fantastic - thank you, gentlemen! I am a developer, so I
understood the concepts of triggers and macros, but was
having trouble applying them to the devices. many thanks!
Brandon
Posted: December 30 2009 at 16:55 | IP Logged Quote Brandon
TonyNo::
I wasn't able to research your tutorial. Is it still available?
Brandon
Back to Top View Brandon's Profile Search for other posts by Brandon
Posted: December 30 2009 at 23:52 | IP Logged Quote TonyNo
Yes, my ISP is now blocking port 80. =/
http://tonyno.ods.org:8080/ph/PHTutorial1-AddingDevicesandMa kingThemDoSomething.htm
