Posted: November 29 2008 at 10:08 | IP Logged
I am trying to transmit from a USB-UIRT to a transmitting Powermid and then from a receiving Powermid to a TV. To test I created a Power On in PH and tested the TV from PH -> USB_UIRT -> TV and it worked. If I insert the Powermids in the chain it will not work. If I use the remote control to the Powermid it works. I have read many threads on the noisy Powermids but most of that dealt with receiving to the USB-UIRT. I even tried the 2 Kleenex trick. Anyone know of any tricks or anything about StarTech Wireless Remote Extender.
And then there’s this:
http://www.smarthome.com/83606/Channel-Vision-Coax-IR-Starte r-Kit-IR-4500/p.aspx
(Look out for blanks from Forum)
Posted: November 29 2008 at 11:47 | IP Logged
Well after much testing I finally got it to work. I found if the Powermid is 12” away from USB-UIRT it picks up a clean signal and send it on. Greater distances evidential pick up more noise and cause a problem. Tony, I know you got this to work, is this what you had to do?
Posted: November 29 2008 at 17:18 | IP Logged
I have my UIRT and Powermid receiver next to each other, both facing a wall that is about 10' away. Works well.
Posted: November 29 2008 at 22:02 | IP Logged
Interesting. Thks…
