Subject Topic: Database Backup Post ReplyPost New Topic
doctorjerry
Posted: January 09 2008 at 18:18 | IP Logged Quote doctorjerry
As a new Powerhome user and nonprogrammer, please explain every step for me to simply backup the database without closing down the program.
I found the following reference,which seems in the ballpark, but I have no idea where this command is executed. Is it a dos level command, or perfomed within powerhome. And if this is the command, I still need help with all the parenthesis'.
ph_backupdb ("C:\HA\PowerHome\Database\Backups\phdbbackup." + string (year (today ())) + string (month (today()), "00") + string (day (today()), "00") + ".db", 0)
Sincerely,
Jerome
Jerome
Back to Top View doctorjerry's Profile Search for other posts by doctorjerry
Posted: January 09 2008 at 20:41 | IP Logged Quote TonyNo
That is a formula that can be put into a macro to be executed automatically which will create backups with a file name that contains the year, month, and day it was run. It backs up up the database to the folder specified, which is C:\HA\PowerHome\Database\Backups. The last parameter, which is zero, means to not overwrite an existing file, if it exists.
A more simple version to just backup to a single file in the root of your c drive each time called would be...
ph_backupdb ("C:\phdb.db", 1)
Creating a macro with either of these is easy...
Launch the PowerHome Explorer (Maintenance, Explorer, or click the E icon in the PowerHome toolbar), navigate to the Macros section in the left pane, right-click in the right pane, select Insert, type in a macro a name (like backup), type in a Description (like backup database) and click Refresh (lightning bolt icon in the Explorer toolbar).
Now, find and click on this new macro in the left pane, move over to the right-pane, change the Command to Formula, make the Value Post, enter one of the formulas into the Send Keys box, then click refresh.
Now, when you want to backup the database, you can select the backup macro in the Macro/Formula drop-down and click Run.
doctorjerry
Posted: January 10 2008 at 11:03 | IP Logged Quote doctorjerry
I created a macro in the macros window as follows
ID = BACKUP
Description = Database Backup
In the Macro Detail windows as follows
Command = Formula
Data = left blank
ID = left blank
Value = Post
Send Keys = ph_backupdb ("C:\phdb.db", 1)
Ran the macro but no file phdb.db is created in c:\
Jerome
jeffw_00
Posted: January 10 2008 at 18:40 | IP Logged Quote jeffw_00
I wrote a really short perl script that copies the backed up db file to a unique name, and call the script from SH as part of the backup macro. Then I created a control panel button that triggered the macro.
One click, and I get a unique backup.
just a thought
Posted: January 10 2008 at 19:50 | IP Logged Quote TonyNo
Based on your saying it didn't work, I checked my c drive and I have no backups! I have been using this forever, but it looks like it stopped working about 1.5 years ago! I need to add some code to make sure the backup happens.
The formula evaluated to a 5 which means "the backup file rename operation fails".
If I change the path to be out of the root of C, it works.
Dave, does this make sense?
ginigma
Posted: January 10 2008 at 20:59 | IP Logged Quote ginigma
Here's what I use in a timed event:
krommetje
Posted: January 11 2008 at 05:46 | IP Logged Quote krommetje
If I change the path to be out of the root of C, it works. Dave, does this make sense?
I have the same problem as TonyNo
Peter
doctorjerry
Posted: January 11 2008 at 13:09 | IP Logged Quote doctorjerry
Glad to see such interest in what I thought was a simple problem.
All suggested formulas worked as long as it's not c: drive.
Hope I don't have to learn Perl script to use the program, but if I do I'll get back to you Jeff.
If have other unrelated questions. Should I continue on this thread, or create a new one for each question?
Jerry
Jerome
cmhardwick
Posted: January 11 2008 at 13:33 | IP Logged Quote cmhardwick
New threads, to keep it simple to track
Cicero, Enjoying automation!
Posted: January 15 2008 at 15:27 | IP Logged Quote dhoward
I know this used to work so it looks like it may be a bug that was introduced with the upgrade from ASA 6 to ASA 7. I'll check into it and make sure it gets squashed.
