Subject Topic: Insteon Groups - Fast ON/OFF Post ReplyPost New Topic
tbeckman
Posted: January 01 2008 at 12:39 | IP Logged Quote tbeckman
I have noticed that when trying to control my groups... if i manually try to turn a group ON... I can no response from the switches... however, if I do a fast on... they seem to work... any reason way this may be. Thank you.
Back to Top View tbeckman's Profile Search for other posts by tbeckman
cmhardwick
Posted: January 01 2008 at 14:06 | IP Logged Quote cmhardwick
when you do a group on, make sure the levels in your group are set to the level you want (255 for full) and the ramprate is fairly fast. if you are calling it from a formula, also you have to put the level in the command, such as ion,255. Faston overrides all this and puts it to full, immediately.
Cicero, Enjoying automation!
