        | bmeeke Newbie
          I am getting a strange error message on my Log file:
           | Posted: December 06 2007 at 19:32 | IP Logged |   |
 Web Access
 OPTIONS / HTTP/1.1
 translate: f
 User-Agent: Microsoft-WebDAV-MiniRedir/5.1.2600
 Host: Hhnn101b
 Content-Length: 0
 Connection: Keep-Alive
 Hhnn101B is the machine that is running Power-Home
 This error pops up and repeats itself every minute.   Not sure what to think.... any suggestions?
 Brian Meeke
        | mustangcoupe Super User
          what is at ip 192.168.1.104
           | Posted: December 07 2007 at 19:41 | IP Logged |   |
 |  it looks to be accessing your web interface....
 Maybe full time?
 Todd Hannemann
 HA newbie
  PowerHome - UPB - ELK   |
        | BeachBum Super User
          I would guess you are trying to access your PH system from another system on your LAN and you don’t have 192.168.1.104 as a Trusted IP in Setup under WEB.
           | Posted: December 08 2007 at 09:33 | IP Logged |   |
 Pete - X10 Oldie
          The log entry isnt an error message per se.  It's showing you that IP 192.168.1.104 is making a request against the PowerHome web server.  It shows that you've got the webserver running (you can disable it if you don't want it).
           | Posted: December 09 2007 at 12:01 | IP Logged |   |
 If it's happening once a minute, it's possible that you've left the Device Status screen open on a web browser on 192.168.1.104 as this screen refreshes once a minute.
 You could go into your webserver setup and add 192.168.1.* to your trusted IP's and then turn off logging for trusted IP access.
        | bmeeke Newbie
          Thanks for the advice.  I will investigate.
           | Posted: December 17 2007 at 21:06 | IP Logged |   |
 Brian Meeke
