Subject Topic: Frustration sets in... Post ReplyPost New Topic
groston
Posted: November 13 2007 at 18:35 | IP Logged Quote groston
Trying to get my system working - and having no luck...
I have an Insteon Lamplinc module whose ID is LIBRARY_LIGHT. From the Device Status screen, I can toggle it on/off. Next step - a timed event. To make sure that I am doing things right, I tried running my formula in the Macro/Formula window. My complex formula is as follows:
INSTEON+LIBRARY_LIGHT+FASTON
When I click run, nothing happens.
Please help. Thanks.
Gerald P. Roston
gerry (at) pairofdocs (dot) net
Back to Top View groston's Profile Search for other posts by groston Visit groston's Homepage
Posted: November 13 2007 at 19:11 | IP Logged Quote TonyNo
That isn't a formula, but a Device Control command string.
groston
Posted: November 13 2007 at 22:15 | IP Logged Quote groston
OK.
Let me ask this question: What should I type into the box, and click run, that will make the light turn on? I also tried:
ph_insteon(LIBRARY_LIGHT, ion, 0)
but that didn't work either.
Gerald P. Roston
Posted: November 13 2007 at 22:27 | IP Logged Quote TonyNo
I see now. OK, try this...
ph_insteon("LIBRARY_LIGHT", ion, 255)
Also, this should work, too...
ph_devicecontrol( "INSTEON+LIBRARY_LIGHT+FASTON")
groston
Posted: November 13 2007 at 23:01 | IP Logged Quote groston
OK, now I just feel stupid...
This image,
shows my setup. I tried typing both commands you suggested in the circled box. In neither case did the light turn on.
Not sure if this is a useful clue, but the drop-down for the circled box does not show any of the many commands I have tried.
What am I doing wrong!
Gerald P. Roston
BeachBum
Posted: November 13 2007 at 23:08 | IP Logged Quote BeachBum
Did you miss Tony's quotes " "
Pete - X10 Oldie
groston
Posted: November 13 2007 at 23:12 | IP Logged Quote groston
Nope - cut-n-pasted from his posting
Gerald P. Roston
BeachBum
Posted: November 13 2007 at 23:24 | IP Logged Quote BeachBum
Stick it in a macro and see if that works. I've experienced the same problem in the past.
Pete - X10 Oldie
groston
Posted: November 13 2007 at 23:58 | IP Logged Quote groston
What does "stick it in a macro" mean operationally? I am looking at the Command drop down box on the Macro Detail screen and have no idea what to select.
Editorial note: I am thrilled that the users of the forum are so helpful because the PH documentation is really quite lacking...
Gerald P. Roston
groston
Posted: November 14 2007 at 00:23 | IP Logged Quote groston
OK - I made have made some small progress.
I wrote a macro - LIBRARY_ON:
Insteon:LIBRARY_LIGHT:Fast On
When I type the macro name into the box and click run, it works! Yeah!
Next step - try this as a times event.
Exact
One shot
Absolute +
1
Macro
LIBRARY_ON
Once entered, hit F5 and wait 60 seconds. Nothing. Also tried restarting PH, but still nothing. Nothing in the log either.
Gerald P. Roston
Posted: November 14 2007 at 08:23 | IP Logged Quote TonyNo
Interesting. I've never used that box for formulas, so I tried it, and see the same thing. It does not work.
Great that you are making some progress, though!
The Timed Event you set up was for a single occurrence and you didn't state the time you used. I'd bet you didn't enter a time in the future. It defaults to right then. When you refreshed, that time had likely passed.
groston
Posted: November 14 2007 at 23:17 | IP Logged Quote groston
Timed events just are not working.
I tried using both a macro (known to work) and a Device Control string, and nothing. Yes, I made sure to set the time several minutes into the future. I F5 saved and restarted PH. Nothing. Nada. Zip.
Is there any chance that working via Remote Desktop is causing a problem? I have no option other than RD as this is a headless server.
I really need/want to get this working. What else can I try?
Gerald P. Roston
groston
Posted: November 14 2007 at 23:39 | IP Logged Quote groston
Problem solved - Timed Events have to be enabled. Only found this by accident...
Gerald P. Roston
