matrix0978 Newbie
Posted: October 26 2007 at 17:48 | IP Logged
Whats up guys,
Ive been looking for a way to automate my house and finally found the solution, PowerHome. I have read through everything about PowerHome and seems perfect i just want to make sure i have the installion concept right. My first project since i am new is to automate all the lights in the house or most of them. I have a touchscreen computer i would install PowerHome on and place on a wall. Would i need to buy a INSTEON PowerLinc Controller, USBfor each light? Or is there any easier way to do this?
Thanks ahead of time
bhlonewolf Senior Member
Posted: October 26 2007 at 18:27 | IP Logged
Hi there,
Nope, that would certainly be quite expensive!
You do need a single PLC, and it essentially acts as a bridge between the PC and the devices. Each device needs to be Insteon-capable (or X10), such as a Switchlinc or ApplianceLinc.
matrix0978 Newbie
Posted: October 26 2007 at 18:55 | IP Logged
do you recommend one?
Posted: October 26 2007 at 19:37 | IP Logged
When it comes to Insteon, the devices you choose really depend on the application. You can replace a standard wall switch with either a dimmer or relay (SwitchLinc or ToggleLincs have both dimmers and relays available), you can use a lamplinc that lets you plug in a standard floor lamp, keypadlinc for multiple buttons, etc. So, I'd say it depends on the application.
matrix0978 Newbie
Posted: October 26 2007 at 19:41 | IP Logged
so what i could do is buy one of those INSTEON PowerLinc Controller(USB) that would connect with the touchscreen(with PowerHome) and then buy multiple SwitchLinc's like THESE that would receive commands from the INSTEON PowerLinc Controller(USB?
Edited by matrix0978 - October 26 2007 at 20:25
Posted: October 26 2007 at 21:09 | IP Logged
Yeah, you could do that -- but my advice would be to go insteon and not x-10 -- if you look at the stats on that item, it's x-10 compatible. Powerhome and the PLC you referenced will do both Insteon and x-10, but if you're starting from scratch, I'd go insteon.
matrix0978 Newbie
Posted: October 26 2007 at 21:35 | IP Logged
okay i just looked for the cheaper one. damn this could get expensive but okay, thanks :)
Posted: October 26 2007 at 22:21 | IP Logged
I suggest you visit Martin at automatedoutlet.com. They also still have some of the lower-cost Icon line of Insteon plug-in modules.
matrix0978 Newbie
Posted: October 27 2007 at 16:10 | IP Logged
do you guys have any suggestions on cheap in-wall speakers?
