| Posted: December 06 2002 at 10:40 | IP Logged
I have been using ActiveHome for a while and have been wanting to do more advanced things than the software supports, then I came across PowerHome and decided to evaluate it.
I have downloaded and installed "PowerHome Runtime Environment" and "PowerHome Executable" Version 1.02.2 on a Windows 2000 machine (the same machine I have ActiveHome working on, so I know the computer is set up correctly). Everything appears to be working well, I have the com 1 set up, and I've only entered 2 modules so far, an 2 way appliance module and a lamp module.
When I go to X-10 Status, the appliance shows up as "Unknown". When I try to turn on either modules through the interface I get the following error: "A timeout occurred while waiting for the Controller to play the X10 code".
Any ideas?
-Tony
