Kremlar Newbie
Online Status: Offline Posts: 37
Posted: August 01 2007 at 17:06 | IP Logged
Running PowerHome v1.03.4.11
DB version 1.03.9.5
Just noticed that I have double entries in my Insteon Device Type list.
Is this a problem? Is it a known issue?
Edited by Kremlar - August 01 2007 at 17:07
Posted: August 01 2007 at 17:39 | IP Logged
Pretty sure that is by design. You might have a switch connected to a load, and another switch acting as a "control" only. To cover all possible situations, you need duplicates for all device types.
Edited by smarty - August 01 2007 at 17:42
Kremlar Newbie
Posted: August 01 2007 at 17:50 | IP Logged
Thanks for the reply.
I think I need clarification... I do have some devices controlling a load, and others for control only - but I don't understand why I would need to choose different Device Types for one or the other.
Could you elaborate?
ginigma Senior Member
Posted: August 01 2007 at 21:28 | IP Logged
Check this thread:
http://www.power-home.com/forum/forum_posts.asp?TID=1051&KW= control+only
Kremlar Newbie
Posted: August 01 2007 at 21:52 | IP Logged
Thanks for the link!
Just to clarify, my database not only has (Control Only) devices, but exact duplicates of everything.
For example, I have:
2476D - SwitchLinc Dimmer 600 watt
2476D - SwitchLinc Dimmer 600 watt (Control Only)
Is this normal?
Posted: August 01 2007 at 22:20 | IP Logged
Hmmm....
I DON'T have duplicates like that.
Sorry to be of no help. Maybe Dave will chime in soon.
bhlonewolf Senior Member
Posted: August 01 2007 at 22:25 | IP Logged
I've got the same thing :)
Posted: August 01 2007 at 22:55 | IP Logged
I think I had the same thing after upgrading. I just deleted the dupes and haven't had any issues since.
Posted: August 02 2007 at 07:46 | IP Logged
Weired....
I check my work machine this morning and it HAS the duplicates. Something's not quite right....
Posted: August 02 2007 at 08:25 | IP Logged
Dupes here, too, but not for every device.
Edited by TonyNo - August 02 2007 at 08:26
Kremlar Newbie
Posted: August 02 2007 at 08:52 | IP Logged
Is it OK to simply go in and delete them?
Posted: August 02 2007 at 11:14 | IP Logged
Dupes here, too but I checked the last version and they had them too.
Edited by BeachBum - August 02 2007 at 11:15
Posted: August 04 2007 at 21:15 | IP Logged
It appears that in either the .11 or .10 database upgrade utility that I inadvertantly created duplicate entries while trying to insure that the Insteon types table had all of the latest Insteon devices.
As such, the dupes don't hurt anything and can be safely deleted. Open the Insteon Explorer and click on the "Types" tab. Delete the duplicate entries but make sure and delete the duplicate entry that is further down the list. They'll be sorted to appear right next to each other but if row 1 and row 2 are identical, delete row 2. Press the Save/Refresh button and then go to the "Devices" tab. Click on the Save/Refresh button and make sure that all of your Insteon devices still show a valid Insteon Type. Fix any that dont and press Save/Refresh.
