Posted: May 23 2007 at 11:33 | IP Logged
Carl,
First off, look in your setup area under logging and turn on ALL the checkboxes. This will make sure thah you can see ALL events that PH sees. Restart PH to make sure the logging is enabled.
Now, after the wierd event occurs, go back to your log file and see what happend just prior to your macro's being fired.
Hope this Helps,
Steve
