Subject Topic: Devices in sync with PH Post ReplyPost New Topic
ginigma
Posted: April 29 2007 at 15:35 | IP Logged Quote ginigma
I'm having some problems keeping my Insteon devices in sync with PH. Meaning that what I see as light settings in the Powerhome web page (Main) and the Device Status screen in the main PH app do not truly reflect the correct device status. Those two screens are in sync with each other, but they show some lights on at some percent dimness, but in fact the lights are off.
Here are my Insteon settings:
I think they are correct? Any suggestions?
Posted: April 29 2007 at 22:16 | IP Logged Quote dhoward
Your settings look good. The biggest problem at the moment is a bug with version 1.03.4.10. The Device status screen will not be updated when PowerHome scans a device for status. Ive already discovered this and corrected it.
However, the other thing that you may want to verify is that all of your devices have a link with the PLC as a responder. If every device has the PLC as a responder, then local control of the devices should keep PowerHome in sync. The only other thing to check would be your communication statistics. If your COMMS are not that great, then PowerHome could be missing commands and your device will be out of sync. If not for the 1.03.4.10 bug, the "Status Scan" would eventually catch this.
Does it always seem to be the same devices? Could the devices in question be controlled by a device that is not in the PowerHome link database or the PLC database?
ginigma
Posted: April 30 2007 at 17:16 | IP Logged Quote ginigma
All my devices are linked to the PLC, so I doubt that's it. I do think I may have a small issue with comms, but I doubt this is it. I think it's mostly when I turn on a light manually. I do have some log files, and I even need to send them to you to take a look at from the email I sent you a week ago. Unfortunately other things have been keeping me busy.
Thanks for the assistance, as always.
