Posted: November 16 2002 at 08:48 | IP Logged
Is there any difference between the LOCALx and MACROx variables? I'm having trouble with the Get Weather macro. I pull out the temp and humidity values fine, but, the forecast part does not work.
Tony
Posted: November 17 2002 at 14:05 | IP Logged
Long time no hear!
There is no difference between the LOCALx and MACROx variables other than the fact that support for the MACROx variables will be dropped in the very near future so be sure and update your database.
I checked the Get Weather macro out and found what the problem was. Apparently Weather Underground has changed their page a little bit and the data for the forecast is past the first 30000 characters. The first line of the Get Weather macro takes the leftmost 30000 characters of the returned HTML to work with. I was able to fix it by changing the 30000 to 50000.
If you want to play with the WSH capabilities, Ive posted the Get Weather macro rewritten as a WSH file below:
sub getweather(zipcode) dim s_html,s_weather,s_temp,l_pos1,l_pos2,l_return
s_html = left(ph.geturl("http://www.weatherunderground.com/cgi-bin/findweather/getForecast?query=" & zipcode),50000) l_return = int(mid(s_html,10,3)) if l_return <> 200 then msgbox "Unable to get URL. Return value is: " & l_return return end if l_pos1 = instr(1,s_html,"<td>Temperature</td>") l_pos2 = instr(l_pos1,s_html,"<b>") + 3 s_temp = mid(s_html,l_pos2,3) if not isnumeric(mid(s_temp,3,1)) then s_temp = left(s_temp,2) end if s_weather = "The temperature is " & s_temp & " degrees. " l_pos1 = instr(l_pos2,s_html,"<td>Humidity</td>") l_pos2 = instr(l_pos1,s_html,"<b>") + 3 s_temp = mid(s_html,l_pos2,3) if not isnumeric(mid(s_temp,3,1)) then s_temp = left(s_temp,2) end if s_weather = s_weather & "The Humidity is " & s_temp & " percent. " l_pos1 = instr(l_pos2,s_html,"<b>Forecast for ") l_pos1 = instr(l_pos1,s_html,"<td align=left><b>") + 18 l_pos2 = instr(l_pos1,s_html,"</b>") s_weather = s_weather & "The forecast for " & mid(s_html,l_pos1,l_pos2 - l_pos1) & " is " l_pos1 = l_pos2 + 9 l_pos2 = instr(l_pos1,s_html,"</td>") s_weather = s_weather & mid(s_html,l_pos1,l_pos2 - l_pos1) do l_pos1 = instr(1,s_weather,"winds") if l_pos1 = 0 then exit do s_weather = left(s_weather,l_pos1 - 1) & "wins" & mid(s_weather,l_pos1 + 5) loop ph.tts s_weather end sub
You can call this script from a macro or sendkeys by executing the function below:
ph_runscript_1("getweather.vb","vbscript",1,0,"getweather","32707")
Substitute your zipcode for 32707. The above line also assumes that you saved the getweather script into a file named "getweather.vb".
Hope this helps.
Posted: November 17 2002 at 17:48 | IP Logged
Cool! Thanks, Dave. I'll have to start playing with the scripts.
Tony
Posted: November 18 2002 at 20:15 | IP Logged
Just an addition...
I added a section to the macro/script that replaces any ellipses ("...") with a period. I got sick of hearing the system pause and then say, "dot"!
Tony
theowl Groupie
Posted: February 28 2006 at 14:43 | IP Logged
It appears that the website has changed again since this WSH. Here's my version of the same script with a few updates...
dim s_html, s_weather, s_temp, l_pos1, l_pos2, l_return
s_html = left(ph.geturl("http://www.weatherunderground.com/cgi-bin/fi ndweather/getForecast?query=" & zipcode),100000)
return
end if
l_pos1 = instr(1,s_html, "</b> °F")-10
l_pos2 = instr (l_pos1,s_html,"<b>") + 3
end if
l_pos1 = instr(l_pos2,s_html,">Humidity:</td>")
l_pos2 = instr(l_pos1,s_html,"#996;") + 7
end if
l_pos1 = instr(l_pos2,s_html,">Forecast for ") +14
s_weather = s_weather & "The forecast for " & mid(s_html,l_pos1,l_pos2 - l_pos1) & " "
l_pos1 = instr(l_pos2,s_html,"<div id=""b"">") +12
l_pos2 = instr(l_pos1,s_html,"</div>")
s_weather = s_weather & mid(s_html,l_pos1,l_pos2-l_pos1) & " is "
l_pos1 = instr(l_pos2,s_html,"<div>") +5
rem Extended Forecast
s_weather = s_weather & mid(s_html,l_pos1,l_pos2-l_pos1) & " should be "
do
loop
ph.tts s_weather
end sub
I have a GETWEATHER macro with a single function line that reads:
ph_runscript_1("C:\Program Files\powerhome\scripts\getweather.vbs","vbscript",1,5000,"g etweather","90210")
A trigger on C16-ON calling the macro completes the job.
Posted: February 28 2006 at 15:19 | IP Logged
Thanks for posting the updated code for us.
Also, be sure and check out the NEW ph_regex functions. They make this type of search and scan operation much simpler. Ive been meaning to do it but just havent had the time with the work being done for Insteon support.
They havent been added to the vbscript module yet, but you can always call them by passing them in with the ph.formula function.
theowl Groupie
Posted: February 28 2006 at 23:49 | IP Logged
Your Welcome...and wouldn't you know that the instant I post the updated code, the site changes!?!
Old line:
New line:
l_pos2 = instr(l_pos1,s_html,"<nobr><b>") + 9
Thanks for the ph_regex suggestion, I'll take a look at that when time allows. I plan on having a lot more website access macros and scripts, so it should come in real handy! First, I have to figure out why the Activehome controller went nuts again and took out all automation controls. I'll be SO glad when I don't have to rely on that thing for remote reception.
