Subject Topic: HELP-PLC issues? Post ReplyPost New Topic
seand
Posted: March 05 2007 at 22:43 | IP Logged Quote seand
OK, I have spent many hours trying to figure this out, and have not found anything that indicates if I have a hardware issue or just a setup issue. I am unable to get power home to communicate with the plc and I have tried 2 different computers. this is the log I get after setting the com port with port=com1 (which is my serial port)
ui:
uifinished:
downloadTimer started
timerActivate not enabled
ui:PORT=COM1
PLC:disconnect=OK
PLC:port=true
uifinished:PORT=COM1
SDM:DM=active,1.01.88.235,3/5/2007 8:21:39 PM,unresponsive,,0.0
I have the control set as Insteon DM
any help would be appreciated, I was unable to get any addiotnal details, as none of the commands returns any info.
Back to Top View seand's Profile Search for other posts by seand
seand
Posted: March 06 2007 at 11:13 | IP Logged Quote seand
OK, I was able to get it to work after killing a bunch of startups (not sure which program was interfering) I cannot seem to get Power home to work with the PLC on my laptop using a USB to serial cable on Com2, has anyone been able to get it to work this way?
Also, I have 2 signal enhancers, do they need to be added to the Power Home database to work? I didn't see them in the listing of devices, and they are not auto discovered.
cmhardwick
Posted: March 06 2007 at 11:17 | IP Logged Quote cmhardwick
as for the signal-lincs, no they are not added to the database. I use a USB PLC, so I can't comment on the other.
Cicero, Enjoying automation!
seand
Posted: March 06 2007 at 12:03 | IP Logged Quote seand
That is what I assumed, but better safe than sorry.   Any comments on the USB-Serial would be great if anyone was able to get it to work.
Posted: March 06 2007 at 12:30 | IP Logged Quote TonyNo
A lot of people have issues with USB-to-serial adapters in general. I have, however, seen good reports on the Edgeport versions, which are common on ebay.
Posted: March 06 2007 at 20:14 | IP Logged Quote dhoward
Cicero is correct, SignaLincs do not show or need to be added to PowerHome.
I actually did development and testing for the serial version of the PowerLinc using a USB to serial adaptor. Im not at home at the moment, so I cant tell you what brand it is. It came from Comp-USA in the notebook computer section and is a single serial port to USB adaptor. It's also what I used to create the controller for the Elk. Works great so far.
seand
Posted: March 07 2007 at 11:35 | IP Logged Quote seand
My USB to serial works great with the ELK M1 G I just wasn't able to get it to communicate with the PLC for some reason. Always returned a 0.0 firmware version and no communication.
