Posted: February 27 2007 at 23:10 | IP Logged
Well, it's finally out!! Version 1.03.4.10 is now available for download. Please let me know if you encounter any errors or problems, it was a bit rushed.
Also on the download page are a couple of PowerHome plugins with full source code. The sample plugin is only useful as a learning tool and is a base skeleton project.
Also, let me apologize. I know I said that I would have the Windows Script Host functions updated with all of the newest PowerHome functions but I just didnt get time. I'll definately have it done for the next version. In the meantime, use of the ph.formula function will allow you access to all of the newest PowerHome functions.
Good luck and let me know of any issues. I'll be catching up on the board messages tomorrow.
nadler Super User
Posted: February 28 2007 at 07:31 | IP Logged
Congratulations on the new version. Can't wait to install it. Just a note on the download instructions.
It reads:
"...Install PowerHome beta version 1.03.4.9 by double-clicking the ph10349setup.exe file and follow the instructions. If you downloaded the Microsoft modules, double-click the msspchapi.exe file before either the msttsl.exe or mscsrgl.exe files. Once the msspchapi.exe file is installed, you may install either the msttsl.exe and/or mscsrgl.exe files by double-clicking them as well."
This might confuse some people (like me).
Posted: February 28 2007 at 11:25 | IP Logged
Noel,
Thanks for catching that. It's fixed now .
Posted: February 28 2007 at 11:31 | IP Logged
All,
ALERT ALERT ALERT!!
I should have known better than to release late at night .
I just caught a problem with the Database Upgrade Utility. It's minor, but needs to be replaced. If your phupg.exe file is dated 2007-02-27, then you need to go to the download page and get the newest phupg.exe file. Ive already patched the ph103410setup.exe file to include the proper version.
If you've got the older version of the phupg.exe file, then any changes made to the plugins or timedeventformulas table will be lost if you do a database rebuild (not an upgrade). The new version corrects this problem.
Sorry guys.
narc Groupie
Posted: February 28 2007 at 12:06 | IP Logged
I'm so excited about this new version! Can't wait to report back.
- jason
Posted: February 28 2007 at 12:57 | IP Logged
Noel,
On the download page, the 4th item down, is the new phupg.exe. You can download the current ph103410setup.exe if you like, but it's not necessary.
Let me know if it's not there.
nadler Super User
Posted: February 28 2007 at 13:49 | IP Logged
I have the 2007-02-27 phupg.exe. I don't see the newer phupg.exe on the download page. I see an old one from 2004 but not the new one. Should I download the newest ph103410setup.exe and reinstall PH?
guerrand Senior Member
Online Status: Offline Posts: 106
Posted: February 28 2007 at 19:32 | IP Logged
ok, it's official...
Added multi-x buffer for incoming X10 extended RF commands (W800RF32A).
You're da man! :D
__________________ VuMe
Viper Groupie
Posted: March 01 2007 at 07:40 | IP Logged
I really like the new layout of the Insteon Device panel The two scroll areas make it much easier to see what I'm looking at. And just one panel makes more sense than two.
I also like seeing the Groups in the Device Status, though I can see I may have to play some games to get them to look like they make sense (or ask for a function which just changes the status in the Device Status area).
I used the Group Clean up/No Group Clean up codes on the InsteonGroup command. Very NICE! A name would make the code easier to read though.
Thanks for all the changes. Your support has made this investment worth it for me.
Tom
onhiatus Senior Member
Posted: March 21 2007 at 16:38 | IP Logged
Hmm, big warning.
The current ph103410setup.exe still seems to have the 2007-02-27 phupg.exe file in it!
Worse, the newer one seems to have been removed from the download page (the fourth item in the download list is "phplugin.zip")
As of right now I am stuck - I can't upgrade my database! when I run the current phupg file I end up with a db that is only 1.3MB (my original db is 780M) and ph won't launch. See my other post for details - Topic: Trouble migrating PH to new computer
