Posted: July 10 2022 at 15:08 | IP Logged
I am making use of ph_createtimedevent() quite a bit but if things go astray I end up with multiple such events in the Timed Events queue.
I thought there was a way to clear these out (in mass) which I want to do in my Initialization routine but can't find the ph command I thought I had previously used to clear out all the "_OS-n" system events.
Is there such a bulk delete and if so what is it?
gadgetGuy
Posted: July 10 2022 at 16:00 | IP Logged
Ken,
There isnt a function directly designed for this but you can easily do it with a database function.
ph_directsql("delete from timedevents where id like '_OS-%'")
The above formula will delete any Timed Event that starts with "_OS-".
Posted: July 10 2022 at 16:48 | IP Logged
Cool Beans!
I never would have thought of that!
Woops didn't work!! But I found the issue... the
"_OS"Timed Events are actually "__OS" events. That is,
there are TWO (2) "_" characters prefixed onto the "OS"
Edited by GadgetGuy - July 10 2022 at 17:37
