MrGibbage Super User
| Posted: September 02 2018 at 07:18 | IP Logged
I finally got me an ISY994 controller. I have been playing with it outside of PH, using just
the ISY Launcher and admin console to make some links and scenes. I want to add it to PH to use
as my primary controller and move away from the USB PLM that I am currently using. I went to
add it as a new controller, and I don't see ISY as an option. And the only options for PLM
require a COM port-no place for an IP address. So, how do I add the ISY controller? Also, is
there a way for PH to look into the ISY & PLM and grab all of the links and scenes in there
already and pull them into the PH database?
__________________ Skip
johnsmith Newbie
| Posted: September 17 2018 at 14:25 | IP Logged
using just
already and pull them into the PH database? |
As long as you are not trying to control the same
devices with both controllers, you should be fine. A
device should only be linked with one HA controller.
If moving a device from one controller to the other, a
factory reset should be done on the device after
removing from one controller and before adding to the
other.
