Subject Topic: System went lost every thing Post ReplyPost New Topic
jsferra1
Posted: January 08 2007 at 06:51 | IP Logged Quote jsferra1
Hello,
My system went on me and I lost every thing I had all my saved email every thing.
I built a new system but I need to get my powr home key, Is there any way to get a new key without paying. for it
    Jim .....
Back to Top View jsferra1's Profile Search for other posts by jsferra1
Posted: January 08 2007 at 07:39 | IP Logged Quote TonyNo
If Dave has your info, he'll email it to you when he sees this.
jsferra1
Posted: January 16 2007 at 19:47 | IP Logged Quote jsferra1
Bump
    Jim .....
Posted: January 16 2007 at 21:43 | IP Logged Quote dhoward
Jim,
Email me your current reg number (Help|About|Registration) to support@myx10.com and I'll generate you the appropriate unlock key.
I could just email you the unlock code you had originally but more than likely you used a different reg name when you re-installed and they would be different.
jsferra1
Posted: January 17 2007 at 13:35 | IP Logged Quote jsferra1
Email with Reg Number has been sent
dhoward wrote:
Jim,
    Jim .....
Posted: January 17 2007 at 21:15 | IP Logged Quote dhoward
Jim,
Got your email and unlock has been sent.
Let me know if you have any problems.
jsferra1
Posted: January 18 2007 at 12:25 | IP Logged Quote jsferra1
Your the best
Thanks for the info .....
    Jim .....
guerrand
Posted: January 28 2007 at 13:45 | IP Logged Quote guerrand
I recommend you do what I did after hitting this same situation.
I set up a timed event to backup the db onto a flash drive on my main pc. I just mapped the flash drive to the server and use the below command to automatically copy it.
ph_backupdb('f:\pwrhome.db',1)
You could also do it to a local flash drive or whatever you like. It just has to have a local drive path.
VuMe
Back to Top View guerrand's Profile Search for other posts by guerrand Visit guerrand's Homepage
twomble
Posted: January 28 2007 at 18:19 | IP Logged Quote twomble
That's a good idea so I decided to set that up. However, when I run the command I get "The formula evaluates to: 4". I checked the help documentation and a return of 4 translates to "Returns 4 if the SQL backup command fails." Do you have to shut down the db somehow first before this command will work?
Tim
Edited by twomble - January 28 2007 at 18:21
Back to Top View twomble's Profile Search for other posts by twomble
guerrand
Posted: January 28 2007 at 18:26 | IP Logged Quote guerrand
No, I have mine run every night at midnight. I don't even touch it. Make sure you have the path it's saving to (the F:\pwrhome.db part in mine) set to a local path that already exists. ph won't create the folder for you if you are saving to a folder.
VuMe
twomble
Posted: January 28 2007 at 18:36 | IP Logged Quote twomble
Yes I did that. On my system I'm using the D: drive (D: is a RAID 5 setup). I made the folder first and tried the command. I still get a return of 4. If you manually run yours does it work?
guerrand
Posted: January 28 2007 at 18:41 | IP Logged Quote guerrand
I'm not sure what could be the problem then. As long as you followed the format of the command just as I had shown it, by all rights it should work. I'd prefer not to actually run it now as it takes about 10-15 minutes to copy my 80MB database. lol
Try setting it to save to the root of the drive as below.
ph_backupdb('d:\pwrhome.db',1)
If that doesn't work we might need to wait for the mighty DAVE to chime in. If anyone can figure it out it's him. :D
VuMe
twomble
Posted: January 28 2007 at 18:47 | IP Logged Quote twomble
That works. If I just tell it to save in the root of the drive I have no problem. If I try to save it in a folder then I get a return of 4. Here's the line that doesn't work for me.
ph_backupdb('d:\PowerHomeBackup\pwrhome.db',1)
guerrand
Posted: January 28 2007 at 19:02 | IP Logged Quote guerrand
Glad that got it. I'm not sure why it would have trouble with directories. Dave would know why.
I've always been saving to the root of the drive since I'm using a dedicated compact flash card to save the db to.
VuMe
Posted: January 29 2007 at 19:03 | IP Logged Quote dhoward
There is currently a bug in the database save routine that has problems with certain naming conventions. It should be fixed in the upcoming beta.
Guerrand,
What concerns me is that your DB file is 80MB. It sounds as if your eventlog has never been trimmed. I would definately look at also nightly trimming or exporting (using ph_exporteventlog or ph_trimeventlog) in addition to your backing up. Also, once you've done something to reduce your eventlog size, then I would run the PowerHome Database Upgrade Utility to compress your database back down to a manageable size.
Let me know if you need help,
guerrand
Posted: January 29 2007 at 19:51 | IP Logged Quote guerrand
I have it trimming now. I didn't realize it but my log was over 1000 pages. yikes! That definitely goes on the nightly maint setup.
*edit*
LOL. That got the db down to 14mb.
Edited by guerrand - January 29 2007 at 20:23
VuMe
Posted: January 31 2007 at 15:29 | IP Logged Quote dhoward
Heh,
Thats definately more like it . Now those nightly backups will be much quicker.
digger
Posted: February 13 2007 at 23:19 | IP Logged Quote digger
I had the same problem and lost my hard drive with everything on it. I decided to build a small server with Windows 2000 Server edition. I am now mirroring my main hard drive.
I also need to get my product key again since I lost my emails as well. I have Powerhome, Homeseer, and CQC and to be honest havent had time to get any of them up and running. I think that Powerhome is the most Insteon friendly but the others are mor ELK friendly at the moment from what I read. I hope that PH and ELK play together more shortly :)
Edited by digger - February 13 2007 at 23:20
Back to Top View digger's Profile Search for other posts by digger
Posted: February 15 2007 at 11:31 | IP Logged Quote dhoward
Digger,
Send me an email with your current reg number and I'll send you the appropriate unlock code. Also, if you can let me know the approximate time that you registered PowerHome, I can go through the history and resend you the RegSoft registration email.
