Plano_Mike Newbie
Posted: November 12 2006 at 00:44 | IP Logged
I am running 1.03.4.9. I loaded my Elk with the all my devices via elkinsteon.exe in a prior version. My Elk is no longer successfully controlling my devices, so I was going to try to run Elkinsteon.exe again. However, I do not find it with the new version.
Dare I try running the old elkinsteon.exe?
TIA.
Mike
__________________ Mike
Posted: November 13 2006 at 15:55 | IP Logged
Mike,
Unfortunately, I didnt get it integrated into the latest version. However, the existing elkinsteon.exe utility should work just fine in conjunction with 1.03.4.9.
Let me know if you have any problems.
jbonja Newbie
Posted: January 29 2007 at 18:07 | IP Logged
Where do I find a copy of the elkinsteon.exe utility? I could not find it on the download page??
Thanks.
BTW, I followed your recommendation from the ELK BB and was able to find all of the device ID's. Now I just have to upload them to the ELK.
__________________ Jeff B
Posted: January 29 2007 at 18:17 | IP Logged
Jeff,
You can get it from this link:
http://www.power-home.com/download/elkinsteon.exe
jbonja Newbie
Posted: February 04 2007 at 11:45 | IP Logged
I downloaded the app but am getting the error:
Application Terminated
Error bad runtime function ref at line 20 in function f_decodepass of object elkinsteon.
I've tried running the program by itself and with PH running in the background.
Any suggestions??
Jeff
jbonja Newbie
Posted: February 04 2007 at 13:45 | IP Logged
OK I found the answer to my question. Elkinsteon has to be installed in the powerhome directory. The answer is in another post.
Thanks.
