Posted: October 29 2006 at 20:57 | IP Logged
Jared,
You should probably go ahead and download the latest beta version 1.03.4.9 and either install fresh or upgrade your 1.03.4.8 version. The latest beta has some fixes in regards to the Control Center.
In the PowerHome Explorer, click on "Control Center" in the left hand pane. The right hand pane should show "Control Center Tabs". Enter an ID and a tab order greater than 0. If the tab order is 0, the tab won't show. Press "F5" to save and right-click the new tab line. Choose "Design" from the popup menu. This will work in 1.03.4.9 but you'll have to first create at least one button in the Explorer before design view will show in 1.03.4.8.
Once you've created a tab, you can also close and reopen the Control Center to see the new blank tab. Right-click on the Control Center tab and choose "Open Design View" from the popup menu to enter design view.
Hope this helps to get you started. Let me know if you have any other questions or problems.
