PowerHome Feature Requests
 PowerHome Messageboard : PowerHome Feature Requests
Subject Topic: Device Status show KPL button state Post ReplyPost New Topic
Paul_PDX
Posted: August 30 2006 at 19:21 | IP Logged Quote Paul_PDX
Would there be any way to have the separate KPL buttons show up in Device Status as an Option?
Something like a kind of a virtual Insteon Device.
Is there even a way in Powerhome at this time to discretely read or set the light on/off state for a given KPL button at this time in a macro?
Back to Top View Paul_PDX's Profile Search for other posts by Paul_PDX
Posted: September 15 2006 at 21:47 | IP Logged Quote dhoward
Paul,
Currently there is no way to get PowerHome to show the status of individual buttons in the Device Status screen. It wouldnt be an easy addition either due to the database being structured to allow only unique addresses in the Insteon table.
There is no way to read the status KPL lights. The byte that controls the status of the individual button lights is not accessible (even by direct peeking or poking...essentially that memory location is protected which is why the KPL util cannot completely set a button as toggle vs on vs off). This bites, but nothing can be done until SmartHome changes the KPL firmware.
You can control a button however via a macro by merely sending a group command. You would need to first create a group with the PLC as a controller and the KPL/button as a responder and then send an on or off command to this PLC group. If a button was configured as a non-toggle on or non-toggle off however, then the group command would be overridden.
The non-toggle aspects notwithstanding, you could probably track button status fairly accurately by creating groups with the individual buttons as controllers and the PLC as a responder and then create triggers which store the status. It would be a little bit of work, but could be done.
