           | Posted: May 12 2016 at 18:14 | IP Logged
Has anyone else been experiencing "Tab Scrollbars" continually getting checked in the Settings area at the top of the Insteon Explorer window?
 I keep unchecking it and a day later it is rechecked, which really messes up working in the "Links" Tab with its split frames.
 I can not determine what in the world keeps rechecking the Scrollbars check box.  BTW Dave there is NO default setting for the Tabs Scrollbar in PH Explorer - Setup Controllers Settings area. Maybe that is part of the problem.
 If anyone else has experienced this issue, have you found a way to force the Tab Scrollbars check mark to always be off?
           | Posted: May 12 2016 at 20:14 | IP Logged
I have not seen this....
 Mine stays "unchecked"....
           | Posted: May 12 2016 at 20:23 | IP Logged
Ken,
 Same here....mine never gets checked.
 I checked the code and there is nothing that will
 automatically or programatically change this box.
 Everytime the Insteon Explorer is opened, it will
 default to this box unchecked. There is no way to save
 it so it is always checked either.
           | Posted: May 13 2016 at 06:29 | IP Logged
Sounds like a mystery!
 Happens once or twice a week on me, and the home
 automation computer sits in a corner and is unused so
 most curious as to what is happening.  Sometimes it will
 even happen multiple times in a day.
 I haven't figured out a way to determine a cause even
 after many, many months of this.
