Subject Topic: bad links Post ReplyPost New Topic
mustangcoupe
Posted: June 10 2006 at 14:51 | IP Logged Quote mustangcoupe
I have a few insteon devices that lost their links... Should PH have caught this and reloaded the links? I do have link checking on in the controler. I did reload the device manually and all is ok. but just wondering
Todd Hannemann
HA newbie
   PowerHome - UPB - ELK
Posted: June 11 2006 at 23:13 | IP Logged Quote dhoward
Todd,
PowerHome will never automatically create or rebuild links. The background link checking only discovers links in devices and periodically scans the devices for any changes and will show you their status.
What you did was correct by hitting the "Rebuild". If PowerHome did automatically rebuild links, then you could never use tap-tap linking because when you unlinked, PowerHome would turn around and relink it.
mustangcoupe
Posted: June 12 2006 at 07:27 | IP Logged Quote mustangcoupe
maybe a optional (check box in setp screen) way a notifying you that the links are bad then.
Todd Hannemann
HA newbie
Posted: June 12 2006 at 17:02 | IP Logged Quote dhoward
The new Insteon Explorer window will show you quickly a list of whats bad, etc. with options to fix.
