seattlechris Groupie
| Posted: June 29 2002 at 15:20 | IP Logged
I'm using the CM17A firecracker transmitter and the MR26A x10 RF receiver. Since I only have one working serial port, I use the CM17A as a pass-through device and plug the MR26A into it. That is, they share the same serial port, which was intended in the CM17A design. I defined both X10 controllers in the setup area of powerhome, and assigned them the same port number. The MR26A works fine, but when I try to send commands to the CM17A, I get the error below. The same thing happens if I subsitute a CM11A for the MR26A. Is the use of pass-through of the CM17A not supported? The CM17A works just fine if I plug it in by itself and limit the powerhome setup by only defining that controller.
Here's the text of the error message from the pop-up screen and the report log:
"A critical error has occurred.
Error Number: 39
Error Message: Error accessing external object property portopen at line 5 in function f_cm17asend of object uo_controller_cm17a.
Window: uo_controller_cm17a
Object: uo_controller_cm17a
Event: f_cm17asend
Line: 5"
