mustangcoupe Super User
Posted: May 15 2006 at 18:27 | IP Logged
I am trying to pull data from a web page, and need help... I am leaving in less then 12 hrs and i need to be able to check the water level in my basement.
the data is in a table looking like this
<TR><TD width=200>Probe 16:</TD><TD>-99.9</TD></TR>
I need to pull out the value -99.9 (it will change # depending on if the sensor is wet -99.9 is dry) then email my cell if it is wet. I thought I had it but I dont.... please help
HA newbie
PowerHome - UPB - ELK
Posted: May 15 2006 at 19:32 | IP Logged
One version you can use is...
ph_regexdiff( "Probe 16:</TD><TD>","</TD>","[LOCAL1]",1,0)
Assuming that you pull the page into LOCAL1.
Tony
Posted: May 15 2006 at 21:25 | IP Logged
thats what I thought Tony
I had.........
ph_regexdiff("<TR><TD width=200>Probe 1:</TD><TD>","</TD></TR>","[LOCAL1]",1,0)
so I tried yours also....
[LOCAL1] = ph_geturl("http://192.168.10.99")
[LOCAL2] = ph_regexdiff( "Probe 1:</TD><TD>","</TD>","[LOCAL1]",1,0)
set GV [basement] = if([LOCAL2]="-99.9","Dry","Wet")
msgbox = [local2]
evaluates to !
HA newbie
Posted: May 15 2006 at 22:27 | IP Logged
Todd,
Try using the ph_getvar_s(1,1) instead of the GV substitution "[LOCAL1]". If the the returned web page has any double quotes like HTML is prone to do, then the substitution will fail.
So, make the code look like this:
[LOCAL2] = ph_regexdiff( "Probe 1:</TD><TD>","</TD>",ph_getvar_s(1,1),1,0)
The other thing I see that may cause you problems is that in your first post you had "Probe 16" but in your other posts you have "Probe 1".
I got your PM so I assume it's with this problem. Let me know if this works or not for you.
Posted: May 15 2006 at 22:43 | IP Logged
Ooh. Interesting.
Posted: May 16 2006 at 06:33 | IP Logged
Sorry for the confision Dave I used probe 16 in the example, but probe 1 is the one actually connected... (it has 16 ports)
That does not fix it... I will have to just vnc in to the ph box and then check the internal webpage from the device while I am gone. I would like to get this working though. and Yes this is what the PM was about I thought you were still online when I signed in, but the database must not have refreshed yet... just missed you
HA newbie
Posted: May 17 2006 at 20:46 | IP Logged
Todd,
When you say it didnt work, do you mean that it didnt produce the desired results or did the formula fail with an "!"?
Let me know when you get back and we should be able to get it working.
Posted: May 17 2006 at 23:19 | IP Logged
Yes dave, it does fail with the !
I will be home this weekend. I hear the rain stopped and I am (my basement is) still dry.....
HA newbie
Posted: May 18 2006 at 14:42 | IP Logged
Todd,
I just tested this on my end and it worked. So there must be something unique on your system that Im not replicating in my test environment.
Let me know when you get home and we'll get to work on it. It may require you to export the macro for me to import so I can test exactly what you're using.
Posted: May 19 2006 at 09:41 | IP Logged
I am home (well at work) I will send you an email with an IP address (I will open my firewall to a port for you)and a copy of the macro.
But I also have other problems running the get weather macro but I thought that was because of a change to their page.... hmmm.... interesting
HA newbie
Posted: May 19 2006 at 13:02 | IP Logged
No problem. Just let me know and we'll get it figured out.
Posted: May 20 2006 at 08:49 | IP Logged
Dave I emailed you my IP/Port and my current macro.
HA newbie
Posted: May 22 2006 at 22:05 | IP Logged
Todd,
Sorry to take so long getting back.
Ive imported your macro and hit the web page and found the problem. The problem was not in the ph_regexdiff but in the line below where you assigned the GV BASEMENT to a formula:
if([LOCAL2]="-99.9","Dry","Wet") |
The problem lies in variable substitution. You're substituting [LOCAL2] which should contain a number and comparing it to a string. This is where the problem is. Variable substitution actually performs a simple search and replace. The [LOCAL2] will actually be replaced with whats in the variable and your formula will look like:
if(-99.9="-99.9","Dry","Wet") |
You can see the number being compared to a string which will result in the BASEMENT GV being set to "!". In order to make this work, you must compare either numbers to numbers or strings to strings. So you could do this:
if("[LOCAL2]" = "-99.9","Dry","Wet") |
or this:
if([LOCAL2] = - 99.9,"Dry","Wet") |
You should also correct the last line where you have a messagebox and change [local2] to [LOCAL2]. Case is important. I would also probably put quotes around [LOCAL2] to make it a string just in case somehow an error occured and a number was not read in. With a string, you can display both a number or alphanumeric.
Posted: May 23 2006 at 07:21 | IP Logged
Thanks Dave, that works great.... The last line was just there for debug I am now setting up a smtp line to email my cell phone...
HA newbie
