Posted: April 30 2006 at 20:24 | IP Logged
I just rearranged one of my tabs, saved it, and it is not showing the updated version. I tried both hitting the Save icon and closing the edit window (which is followed by a "Do you want to save" dialog).
Posted: May 01 2006 at 23:38 | IP Logged
After you've saved the tab, are you closing the Control Center and reopening it so that it will load the changes? Editing a tab will not update a currently open CC with the changes.
Posted: May 02 2006 at 07:44 | IP Logged
Yup. I even tried closing the CC after starting the editing. Seems to be another flash in the pan. I just tried again, and it worked this time. I'll see if I can duplicate it.
