PowerHome Programming
Subject Topic: Creating a toggle button Post ReplyPost New Topic
fasttimes
Posted: April 22 2006 at 16:11 | IP Logged Quote fasttimes
I have a ceiling fan connected to an insteon switch (non-dimmmer) and want to create a macro to toggle the current status. Is this possible?
I also want to create a button on the control center that will have an on/off position (down for on, up for off, or using colors instead). I also want the button to reflect the status of the device if the fan is turned on from the switch or another insteon device.
Any suggestions?
Back to Top View fasttimes's Profile Search for other posts by fasttimes
Posted: April 22 2006 at 18:20 | IP Logged Quote TonyNo
Sure! You can do it on one line with a formula in a macro...
case( ph_getinsteonstat( "FAN" ) when 1 then ph_insteon( "FAN", ifaston, 0) when 2 then ph_insteon( "FAN", ifastoff, 0) )
I don't have on/off Insteon devices, so I'm guessing at faston and off.
For the on/off in the CC, there is a reply in a thread you started here, and also good info here, too.
Edited by TonyNo - April 22 2006 at 18:21
fasttimes
Posted: April 22 2006 at 20:44 | IP Logged Quote fasttimes
Thanks for the reply. That formula works nicely.
Is there a way I can modify that so I can create my own formula and use it everywhere in PH?
For example, I could call something like
myToggle("FAN")
if I had something like the following below?
Function myToggle(ItemID as String)
return
case( ph_getinsteonstat( ItemID ) when 1 then ph_insteon( ItemID, ifaston, 0) when 2 then ph_insteon( ItemID, ifastoff, 0) )
End Function
Posted: April 22 2006 at 21:45 | IP Logged Quote TonyNo
I think the only way to do that would be in a macro that can receive parameters. You would then call it via ph_macroparm(). I do this in my announcement macro.
Your TOGGLE macro would be...
case( ph_getinsteonstat( "[TEMP1]" ) when 1 then ph_insteon( "[TEMP1]", ifaston, 0) when 2 then ph_insteon( "[TEMP1]", ifastoff, 0) )
And you would call it with...
ph_macroparm ( "TOGGLE", "FAN", 0, 0, 0, 0 )
fasttimes
Posted: April 23 2006 at 02:41 | IP Logged Quote fasttimes
How do I "create" this macro?
When I paste
into the formula column of the macro, it evaluates to <nothing>.
When I am creating this macro, what is the "command type"?
Posted: April 23 2006 at 09:14 | IP Logged Quote TonyNo
Correct. That is because TEMP1 is nul. It will only evaluate properly when called with ph_macroparm.
Command type is formula.
Posted: April 24 2006 at 16:14 | IP Logged Quote dhoward
Just a slight correction I need to make...
The ph_macroparm function passes the parameters using the LOCAL variables instead of the TEMP variables.
So the macro line shoule look like:
case( ph_getinsteonstat( "[LOCAL1]" ) when 1 then ph_insteon( "[LOCAL1]", ifaston, 0) when 2 then ph_insteon( "[LOCAL1]", ifastoff, 0) )
Posted: April 24 2006 at 19:25 | IP Logged Quote TonyNo
Doh! I need to pay more attention to detail!
Posted: April 25 2006 at 22:42 | IP Logged Quote dhoward
Happens to the best of us .
