bmwragtop Newbie
Posted: August 19 2015 at 18:54 | IP Logged
Hi,
My computer crashed on me, and once I restarted Windows, I went to
restart Power-Home. Power-home starts up fine if I do not start the
event timer. Once I start the event timer, the "busy" icon appears and
Power-Home becomes unresponsive.
If I don't start the event timer, everything else works fine.
Has anyone seen this before?
Tom
Windows 7 on Linux based VM
Posted: August 19 2015 at 19:12 | IP Logged
What happens if you later enable the time events?
bmwragtop Newbie
Posted: August 19 2015 at 19:30 | IP Logged
I tried waiting for several minutes, and then when I start the timer, it hangs.
I'll wait a day to see if things settle out, but I am not hopeful.
Tom
gg102 Senior Member
Online Status: Offline Posts: 245
Posted: August 19 2015 at 19:35 | IP Logged
This was am issue with previous versions. What happened was that events happened in the past (before the current date/time) it would cause PH to get confused. I'm sure Dave can explain all the details if you're interested.
Dave made a couple fixes to fix this issue. Probably if you install the current version, 2.1.5d, you'll see this issue go away. I have not seen this issue since Dave fixed it.
I recommend that you move to the current version if you're not there.
bmwragtop Newbie
Posted: August 19 2015 at 19:41 | IP Logged
Thanks. I am presently running 2.1.5a.
Posted: August 20 2015 at 15:55 | IP Logged
I would upgrade to R2.1.5C as it is pretty stable.... As I recall there was some latent timer issues with 1.2.5A
