dmoreno Newbie
Posted: March 25 2002 at 04:53 | IP Logged
I was wondering, Do we have access to the variable for the button color? I was thinking if we did, how nice it would be to change the color of the button to use this as a status. If you have a light switch and the power is off, you might set the variable for that button red. And, if it were on make it green. This couls also cut down on the number of buttons. Just use one button for a wall switch. If the color is red and you press it,it will change green and turn power on to the wall switch. and vice-versa.
Posted: March 25 2002 at 10:34 | IP Logged
No, currently its not available. One of the things that is being worked on is additional objects for the Control Center, one of which was going to be a multi-state button like you describe. I was originally going to use pictures, but will also look into adding one so that you can merely change color and/or text.
Posted: April 09 2002 at 20:43 | IP Logged
Ooh, I like the color idea! Simple and elegant.
Tony
