Subject Topic: phone control Post ReplyPost New Topic
phil13
Posted: February 13 2005 at 01:27 | IP Logged Quote phil13
Hi,
it is possible to manage powerhome through a phone line (without internet) ?
I'd like for example :
- call my system from anywhere
- could hear a menu from powerhome (1:alarme state, 2:X10 command , ...)
- ask it by dtmf tone the alarm state and change it
- turn on my coffee machine
- turn of ....
Philippe
Back to Top View phil13's Profile Search for other posts by phil13
seattlechris
Posted: February 13 2005 at 12:28 | IP Logged Quote seattlechris
There's no direct way, no.
I'm planning on eventually doing exactly what you're suggesting on my system though, by combining PH with other software. PH would control the x10 and alarm functions, and PH would use sendkeys or window API commands to control third party software that handles modem and DTMF functions. I probably won't get around to it for months though.
You can do many of the things you want by buying an x10 telephone transponder, like those for sale at smarthome: http://www.smarthome.com/x10telephone.html.
Alternatively if you're able and willing to use text messaging from your phone you can use email to PH for remote control, which is what I do currently (details elsewhere on this forum).
Back to Top View seattlechris's Profile Search for other posts by seattlechris
Posted: February 14 2005 at 16:26 | IP Logged Quote dhoward
Phil,
PowerHome does not currently support TAPI (Telephone Application Programming Interface). I was working on it many months ago, but the Microsoft TAPI interface was so flaky, it wouldnt stay running long enough for me to even test.
I would like to one day get back to this issue, but it is a ways off in the future.
phil13
Posted: May 19 2005 at 10:58 | IP Logged Quote phil13
dave,
why not directly manage modems as any rs232 device using "AT" commands ?
Posted: May 19 2005 at 11:36 | IP Logged Quote TonyNo
Phil,
PH can communicate with RS232 devices, but the AT command set does not support tone recognition, nor speech, AFAIK.
phil13
Posted: May 19 2005 at 13:56 | IP Logged Quote phil13
Thanks tony,
What is AFAIK ?
My modem (an olitec self memory) can send and receive .wav files with AT commands but i don't know if i can decode DTMF codes ...
Otherwise, it seems that homeseer software can manage voice modem without tapi.
It is not possible to do it in the same way ?
Posted: May 19 2005 at 19:58 | IP Logged Quote TonyNo
AFAIK = As Far As I Know
I'll check with my HS pals and report back!
Posted: May 19 2005 at 22:18 | IP Logged Quote TonyNo
HS Phone only works with these two modems, and it does not use TAPI.
phil13
Posted: May 20 2005 at 02:56 | IP Logged Quote phil13
Why not try to combine standard voice modem with AT command and a software like that :
http://www.tapiex.com/PhoneToneDecoder.htm
http://www.softizer.com/show_product/software_development/ac tivex/phone_tone_decoder/
My idea is to connect my modem to the pc sound card and use this kind of software to decode tone in live and use ph.tts to send voice.
So perhaps with rs232 AT commands and tone decoder software with sound card, i could automate powerhome by phone ...
Do you think it will be possible ?
phil13
Posted: May 20 2005 at 07:05 | IP Logged Quote phil13
An other solution will be perhaps to connect on the telephone line a DTMF decoder in parallel with the modem.
Something like that :
http://www.alltronics.com/download/k153.pdf.
I have to use a serial port for the voice modem (with AT command) and another for the decoded dtmf.
For the speech, if i connect my output sound card to the voice modem, with ph_tts, i can speak to the telephone line.
So i could manage the modem with AT command, capture DTMF command on another serial port, make ph command and answer with ph_tts on the telephone line.
Do you think it is possible ?
phil13
Posted: May 20 2005 at 07:56 | IP Logged Quote phil13
just a "little" (big) error :
to send voice to the phone line, you have to send a .wav file to the modem, and not connect sound card because there is no voice input on the modem ...
Posted: May 23 2005 at 17:21 | IP Logged Quote dhoward
I don't think this would be possible without either TAPI or writing dedicated code specific to a couple of modems (apparently what HS has done). However, this is currently a little out of my range of expertise so don't take my word for it .
phil13
Posted: May 24 2005 at 12:46 | IP Logged Quote phil13
Ok Dave,
Just for information, i've begun to make my phone application with excel VBA and AT commands of my voice modem (I don't use TAPI).
I've not finished yet but today i can send/receive calls, detect caller ID, send/detect tones and send/receive voice messages (.wav files).
To do that, i've used an answering machine (the best one for me is www.ventafax.com) and a serial port monitor (
http://www.aggsoft.com/serial-port-monitor/) in spy mode.
I've then just reproduice the dialog with MSCOMM.
When i've finish, i'll try to do the same in powerhome with scripts and macros.
Philippe
Posted: June 01 2005 at 11:51 | IP Logged Quote dhoward
Philippe,
If you come up with any scripts or macros for telephone control within PowerHome, I'd love to see them. If it's generic enough, I'll look into building it directly within PowerHome.
phil13
Posted: July 12 2005 at 00:28 | IP Logged Quote phil13
sorry, i've seen your answer before today ....
I've tried to manage phone with vb express 2005 and with vba in excel. I've used standard AT commands.
I've created the basics macros (hang, call, play, rec, ...) but not the full program.
If you want my macros, i can send them to you.
Philippe
