phil13 Groupie
Posted: December 28 2004 at 11:59 | IP Logged
Hi,
after have spent many hours trying to use ph_getwebparm i found the good syntax.
Here is the code for someone interrested :
You first create ESSAI as global variable in powerhome.
You copy the following code in a file and save it as "example.psp" in the powerhome web directory.
in a browser, you call localhost/example.psp
You enter a value, hello for example and click on the button. And hello go in the ESSAI field.
<html>
<head>
<meta name="GENERATOR" content="Microsoft FrontPage 5.0">
<meta name="ProgId" content="FrontPage.Editor.Document">
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<title>Nouvelle page 1</title>
<script language="JavaScript">
function updatePHfield(PHfield, webfield)
{document.execsendkeys.sendkeys.value = "ph_setglobal_s ( '" + PHfield + "', ph_getwebparm('" + webfield + "') )" ;document.execsendkeys.submit(); }
</script>
</head>
<body bgcolor="#C0C0C0">
<form method="post" name="execsendkeys" action="/ph-cgi/execsendkeys">
<input type="hidden" name="sendkeys" value="">
<input type="hidden" name="nexturl" value="/essai2.psp">
<p align="center"><font size="6"><b>ph_getwebparm test</b></font></p>
<input type="text" name="AAA" size="20">
<input name="a1on" type="button" value="write in Powerhome 'ESSA'I global variable" onclick="updatePHfield('ESSAI', 'AAA')" style="color: #008000" name="a1on">
<p>
</form>
</body>
</html>
Posted: December 28 2004 at 23:28 | IP Logged
Philippe,
I cant remember if you had asked me concerning PSP samples or not and if so, Im sorry I havent had a chance to get some together.
I tested out your code and it indeed works, though I havent taken the time to trace the code to find out why . However, it was not the intended method of use for the ph_getwebparm function. Ive pasted a couple of simple examples that go together below showing PSP programming and the intended use of the ph_getwebparm function.
The main PSP page is pasted below. In my sample, Ive named it "macrolist.psp" and placed it in the web directory. It dynamically builds a dropdown list box of available macros to play within PowerHome.
<html>
<head>
<title>PowerHome Macro List</title>
</head>
<body bgcolor="#ffffff">
<form method="get" action="playmacro.psp">Macro: <select name="id" size=1>
<option value="">
<% ph_rtne(ph_sqlselect(1,"select id from macroheader order by 1") + ph_setvar_a(1,1,1) + ph_doloop("ph_concatvar(1,2,'<option value=~~"' + ph_getdata(1,ph_getvar_n(1,1),1) + '~~">' + ph_getdata(1,ph_getvar_n(1,1),1) + '~r~n') + ph_rtne(ph_addtovar(1,1,1))","ph_getvar_n(1,1) <= ph_getsqlrows(1)")) + ph_getvar_s(1,2) + ph_rtne(ph_sqldestroy(1)) %>
</select>
<input type="submit" value="Play">
</form>
</body>
</html>
When you press on the "play" button, the "playmacro.psp" file will be called. This file uses the ph_getwebparm function to retrieve the value of the passed macro ID, plays it, and then redirects the page to the "macrolist.psp" file. The source is below:
<% ph_rtne(ph_macro(ph_getwebparm("id"))) %>
<html><head><title>PowerHome Redirect</title><script>location.replace("macrolist.psp")</script></head></html>
Hope this sheds a little light on PSP pages for anyone whose interested.
Posted: December 28 2004 at 23:45 | IP Logged
Thanks, Dave. I was one person that asked about that.
Posted: December 29 2004 at 00:35 | IP Logged
Oops, Sorry Tony .
Posted: December 29 2004 at 01:04 | IP Logged
I don't doubt that Phil asked, too.
It seems that using the sql stuff can really make PH shine.
phil13 Groupie
Posted: December 29 2004 at 04:36 | IP Logged
ouaha !
Even if i don't really understand your formula ... i find impressive the power of using sql in powerhome.
I think i have to learn SQL if i want make something really interesting.
Also, if you have others little piece of SQL code ...
Posted: December 30 2004 at 23:18 | IP Logged
Well, dont have any specific pieces so will give a many SQL primer.
First off, PowerHome uses the Sybase Adaptive Server Anywhere Relational SQL database engine. A big name for pretty much just a structured file. This file is pwrhome.db in the database directory of PowerHome and is simply referred to as the database. Part of the engine is a separate executable that is our interface to the database. This executable handles retrieving, inserting, and updating of data within the database. The way we communicate with the engine is with a standardized language called SQL (Structured Query Language). Even though SQL is a standard, of course everyone who implements it adds their own flavor.
Before we delve into SQL, lets talk a little about a database. A database is a repository for data. It mainly consists of tables with each of these tables containing rows and columns. Each table will usually contain related data with this data being broken down into columns. A simple example would be a table containing data about an employee. You would want to know the employee's first and last name, employee number, hire date, salary, etc. Each of these related pieces of information would be contained within individual columns. The information for a single employee would be a record or a row within the table. If you had 10 employees, you would have 10 rows. While the structure of a table (the columns) is more or less fixed (it can be changed while designing), you can insert, delete, or update rows at will (you've hired employees, fired employees, or gave them a raise ;-)
Each column of data, will be of a specific type, usually character (such as their name), numeric (such as salary and employee number), or a date (such as the hire date). The data you place within a column must match the datatype of the column.
In addition to tables containing data within a database, you will usually have indexes and primary keys on your tables. An index will speed searching and retrieving of data from the database. A primary key (unique) creates an index on the table as well as ensures that no duplicate records can be created. When you create an index or a primary key, you identify what columns make up the key or index. In the case of the primary key, the column or combination of columns must contain unique information from one row to the next.
Databases can also contain their own code and "rules". When you update a row in one table, you could have a "trigger" that automatically updates a row in another table.
The last piece of background to introduce is table relationship. Usually tables are related to one another. Often this relationship is a "parent-child" relationship. In PowerHome, we can see this in the MACROHEADER and MACRODETAIL tables. The MACROHEADER table contains the ID and DESCRIPTION of a macro as well as whether it should appear in the macro dropdown listbox, etc. The MACROHEADER table contains one and only one row for each macro (the ID is unique and is the primary key). The MACRODETAIL table contains the individual lines that make up the macro. If your macro has 10 lines of code, then the MACRODETAIL table will have 10 rows for that macro. This is also called a "one to many" relationship.
Now thats out of the way, lets talk a little about SQL. The structure of the PowerHome database is detailed in one of the appendices of the PowerHome Users Guide. It lists each table and the columns and datatypes that make up the tables. There are a number of SQL commands but the most commonly used during database access are INSERT, UPDATE, DELETE, and SELECT. They are pretty much self-explanatory. The INSERT statement will insert new rows into the database and the DELETE statement will remove existing rows. The UPDATE statement will modify data within the database and the SELECT statement will retrieve data from the database.
We'll concentrate on the SELECT statement here. The general structure of the SELECT statement is:
SELECT column1,column2,columnxx FROM table1,table2,tablexx WHERE condition1 = xx
You must start each SELECT statement with the word SELECT. You will then have a comma separated list of column names containing the data you wish to select. You must follow this with the FROM keyword and then follow that with a comma separated list of table names containing the columns you are selecting data from. The WHERE clause is optional and allows you to limit the data by applying conditions.
Now, how is this immediately useful? Where, since the betas have been released, the manual has not been updated with the latest database changes. Under the "Reports" menu of PowerHome is the "SQL Query" report. Choosing this opens a window where you can type a freeform SQL statement to query the PowerHome database. As long as we know the name of a table, we can see it's columns as well as all of its rows by entering in the following SQL statement:
select * from tablename
The asterisk is a wildcard character and means to retrieve all columns from the specified table. To get a list of all the rows and columns of the MACROHEADER table, we could type:
select * from macroheader
Once we see the structure, we could then modify the SQL so that we get a list of all the rows and show just the ID and DESCRIPTION columns by typing:
select id,description from macroheader
If we wanted to play with the WHERE clause, we could say give me just the macros whose ID starts with A by typing:
select id,description from macroheader where id like 'A%'
A little explanation is due. The % (percent sign) in the where clause is a wildcard. The ID columns is a character datatype and in SQL, character types are always delimited by single quotes. If you are using wildcard characters in the where clause, then the required relational operator is "like". If we wanted to retrieve just the macros whose ID were "A", then we would type:
select id,description from macroheader where id = 'A'
We don't have a wildcard, so we use the "=" relational operator. If we actually have a macro with an ID of "A", then our SQL would return a single row (the primary key of MACROHEADER is ID and no more than one macro can ever have an ID of "A"). If we didnt have a macro with an ID of "A", then no rows would be returned.
To finish up this intro, let also talk about an additional clause for the SELECT statement that allows us to sort the retrieved data. It is the ORDER BY clause and appears after the WHERE clause. If we wanted our data sorted by the ID column, then we would type:
select id,description from macroheader order by id
I'll conclude this into with a link to an online reference for Adaptive Server Anywhere:
http://sybooks.sybase.com/onlinebooks/group-sas/awg0700e/dbrfen7
Posted: April 04 2005 at 08:35 | IP Logged
Finally getting around to digesting this.
It looks like this portion of playmacro.psp...
location.replace("macrolist.psp") |
Should be like this...
location.replace("/macrolist.psp") |
Tony
Posted: June 05 2005 at 17:19 | IP Logged
Back to the topic...
I'm trying to use ph_getwebparm here:
<% ph_irdesc( ph_getwebparm ( "dev" ), ph_getwebparm ( "key" ) ) %>
<table border="0" width="221" cellspacing="0" cellpadding="0">
<tr>
<td width="49"><a href="?dev=DIRECTIVO&key=EXIT"><img src="/images/pdadtv_0.bmp" width="49" height="45" border="0" alt="exit"></a></td>
Am I not doing this correctly? Do I need to assign the parameter to a local?
Posted: June 05 2005 at 20:48 | IP Logged
Nevermind, I got it!
Posted: June 06 2005 at 16:34 | IP Logged
What was it? The syntax looked correct.
Posted: June 06 2005 at 18:59 | IP Logged
I was calling an IR command that I didn't learn yet.
Posted: June 10 2005 at 15:46 | IP Logged
Dohh!!
Posted: June 21 2005 at 21:08 | IP Logged
Is there a way to tweak this...
<% ph_rtne(ph_sqlselect(1,"select id from macroheader order by 1") + ph_setvar_a(1,1,1) + ph_doloop("ph_concatvar(1,2,'<option value=~~"' + ph_getdata(1,ph_getvar_n(1,1),1) + '~~">' + ph_getdata(1,ph_getvar_n(1,1),1) + '~r~n') + ph_rtne(ph_addtovar(1,1,1))","ph_getvar_n(1,1) <= ph_getsqlrows(1)")) + ph_getvar_s(1,2) + ph_rtne(ph_sqldestroy(1)) %> |
...to list out something like Global variables?
Edited by TonyNo
Posted: July 18 2005 at 16:27 | IP Logged
Below is the above code (tweaked a little bit using the latest functions) set to retrieve the ID's of the global variables.
<%ph_rtne(ph_sqlselect(1,"select id from global_variables order by 1"))%>
<%ph_rtne(ph_forloopwinc("ph_concatvar(1,2,ph_getdata(1,p h_getvar_n(1,1),1) + '<br>~r~n')",1,[SQLROWS1],1,1) + ph_sqldestroy(1))%>
<%ph_getvar_s(1,2)%>
Also take a look at the below code. It uses PSP to call a vbscript to simplify the looping code. Kind of a quasi-ASP way to do it.
The first is the PSP file:
<%ph_rtne(ph_runscript_0(ph_getphwebdir() +
"\ttgv.vbs","vbscript",0,0,"main"))%>
<html>
<body>
<table>
</table>
</body>
</html>
The second is the vbs code in a file (located in the PowerHome web directory but could be really anywhere) named "ttgv.vbs"
sub main()
dim i_row,i_rows
dim s_html
ph.sqlselect 1,"select id,value from global_variables order by 1"
i_rows = ph.getsqlrows(1)
for i_row = 1 to i_rows
s_html = s_html + "<tr><td>" + ph.getdata(1,cint(i_row),1) + "</td><td>" + ph.getdata(1,cint(i_row),2) + "</td></tr>" + vbcrlf
next
ph.sqldestroy(1)
ph.setvar_s 1,2,s_html
end sub
Hope this opens up new avenues for you to explore.
Posted: July 18 2005 at 17:34 | IP Logged
Sweet! Digestion of code commmencing in 01:24:00!
Posted: July 18 2005 at 20:53 | IP Logged
Uhm, the first code block does not work and the script version crashed PH.
Posted: July 19 2005 at 10:08 | IP Logged
I checked out the code and think Ive found the problem with the first PSP script. If you look at the copy and paste below:
You can see a space between p and h in the ph_getvar_n. Don't know why this editor goofs up code copies and paste but this is probably the problem.
I also looked at the vbscript code and could not find a problem. If you copy and paste just the vbscript into the script editor and do a "Check Script", do you get back any errors? What happens when you run it? When you say crashes PowerHome, does it give you any kind of error message?
Let me know and we'll get it worked out.
Posted: July 19 2005 at 20:15 | IP Logged
Good catch, Dave!
Here is the result of me playing with the first PSP bit. It creates a table to display the global name and its value. I just noticed that the psp/vbs bit does the same thing!
<html>
<body>
<table>
<% ph_rtne( ph_sqlselect( 1, "select id, value from global_variables order by 1")) %>
<% ph_rtne( ph_forloopwinc( "ph_concatvar( 1, 2, '<tr><td>' + ph_getdata( 1, ph_getvar_n( 1, 1),1) + '</td><td>' + ph_getdata( 1, ph_getvar_n( 1, 1), 2) + '</td></tr>~r~n')", 1, [SQLROWS1], 1, 1) + ph_sqldestroy( 1)) %>
<% ph_getvar_s(1, 2)%>
</table>
</body>
</html> |
Now the psp/vbs works! Maybe that "p h_" set up a bad situation?
