PowerHome Programming
Subject Topic: Timed Event or Triggers Disable/Enable Post ReplyPost New Topic
GadgetGuy
Posted: May 14 2013 at 06:42 | IP Logged Quote GadgetGuy
PROGRAMMING TIP
There are times when one wants to disable All Trigger
Events or Timed Events for the duration of a critical
macro, so that the macro is not impacted.
This is equivalent to turning Interrupts on/off in a
real-time system, when a time/state critical operation is
being executed and must not be interfered with.
At this time (May 2013) there are no PH commands to
disable/enable all Triggers, but the same result may be
obtained using the following PH Direct SQL formulas . . .
(Enables all Triggers)
ph_directsql("update triggers set status = 1")
(Disables all Triggers)
ph_directsql("update triggers set status = 0")
To similarly Enable/Disable Timed Events, use the
ph_timedeventsctrl function.
To Disable all Timed Events, you would use:
ph_timedeventsctrl(“off”,0)
And to Enable all Timed Events (and execute past
due
events) use:
ph_timedeventsctrl(“on”,1)
Whenever Triggers or Events are Disabled, be SURE to re-
enable them ASAP as soon as done. If these functions are
ever left Disabled, your PH functionality will pretty
much cease!
It is probably a good programming practice to always
Enable both Triggers and Events in your PH Initialization
routines.
Edited by GadgetGuy - May 14 2013 at 08:04
smarty
Posted: May 14 2013 at 07:13 | IP Logged Quote smarty
Nice tip....
Thanks!!
