PowerHome Programming
Subject Topic: New Dual Band Switches and Groups Post ReplyPost New Topic
tbeckman
Posted: February 10 2013 at 20:31 | IP Logged Quote tbeckman
I had to replace a few switches and I order the newer dual band switches... they work well if I send a single to turn them on/off. But when I add them to a group from powerhome, I can't get them to respond. Other older switches still respond to the same group. I can see in powerhome that the group as been programmed... but can not control those switches when a group command is sent. Any others have this issue before? Thanks.
Back to Top View tbeckman's Profile Search for other posts by tbeckman
grif091
Posted: February 10 2013 at 21:25 | IP Logged Quote grif091
New devices are I2CS which requires the I2CS support ZIP file installed on top of 2.1.4.   Also the Enable Pending and Status Scan options must be active to complete an I2CS device add.
Here is the link to the I2CS support ZIP
http://www.power-home.com/forum/forum_posts.asp?TID=3126&PN= 2
Edited by grif091 - February 10 2013 at 22:19
Lee G
