fstlouis Newbie
Posted: November 08 2012 at 16:47 | IP Logged
I replaced a failed device with a new Switchlink 2476D v3.2. However, whenever I try to create links on the device, all the links on that device (responder or controller) never get saved, they stay stuck in FLAGGED CREATE state. The other side of the link on other devices does go get created.
I am running PowerHome 2.1.4 with the I2CS patch. I did the clear failed, clear comm. I deleted the device and all links, then re-discovered it. The device does not show up as disabled, but I check the box, saved, then unchecked it again and re-saved.
I am able to control the device directly from PowerHome. And I am am to create links between two devices manually.
Comm reliability for that device is 100%.
