pingmustard Newbie
Posted: September 23 2012 at 02:27 | IP Logged
Could someone help with a noob question here... I tried creating a formula called with id "REFRESH_LOGS". The function just sets some global and deletes some old file. I'm able to Right click > Play to test formula and the log files are refreshed as expected.
Inside the PH Multi-Editor, I'm trying to manually call this formula... all the below has failed me. Can someone shed some light how formulas are suppose to be called?
Failed lines w/ SYNTAX ERROR:
REFRESH_LOGS()
REFRESH_LOGS
ph_formula("REFRESH_LOGS()")
ph_formula("REFRESH_LOGS")
Posted: September 23 2012 at 07:52 | IP Logged
ph_formulabtn("TURNONICON")
pingmustard Newbie
Posted: September 23 2012 at 18:25 | IP Logged
ph_formulabtn did the job! Thanks!
Was there some special meaning to "btn", my first thought was button, which was probably why I overlooked this routine :)
